Turf tires killing grass
   / Turf tires killing grass #1
csquared63
Western New York
John Deere 790
I have a JD 790 with filled turf tires. If I drive over the same area more than a few times, the grass is killed. The only thing I can think of why this is happening is because the tractor is too heavy with the filled rear tires.
Would I be correct?
Thanks
   / Turf tires killing grass #2
It depends on how soft the ground is, possibly. I had a neighbor who couldn't mow around trees with his SCUT because he would take the exact turning circumference around the tree and that started digging it up.
I had a 3720 with filled R4s and never had a problem, maybe because I don't take the exact same turns every time.
   / Turf tires killing grass #3
Another consideration with a 4WD is due to the front lead damage will occur especially in turns.
The solution is to dis engage 4WD in all turns.
Thanks guys. This was mostly just straight driving. I did have it in 4WD and it occured to me that it might be an issue, but as I said it was mostly straight. I made several trips down a trail with a full loader. The ground was pretty dry. My neighbor drives all over his lawn, a lot more than I do, and I don't see the tracks.
Here are two shots showing the damage. In the first, I only traveled twice over the grass. In the second, I probably made 20 trips.
   / Turf tires killing grass #5
A bunch of trips over the same area is obviously going to kill it. Unless it’s super dry I don’t know why one trip is hurting anything. My tractor is heavier and my other tractor was a lot heavier and they never killed the grass. Take it out of 4wd unless it’s needed.
   / Turf tires killing grass #6
I wonder if it might be due, in part, to the type of grass. Around here my "lawn" is field grass that has been mowed into submission for 36+ years. I can drive my M6040 with R1 tires(weighs 10,100 pounds) on the lawn - it will leave chevon marks - it wills skerf up the grass if I make a turn - it sure won't kill any of the grass.
I don't make a habit of driving out on the lawn with the tractor.
Now my riding lawn mower - JD G100 - has turf tires and, obviously, I drive it all over the lawn. Never killed any grass or tore up any lawn with it.
I think the answer is very obvious - like with my tractor - STAY OFF THE LAWN.
   / Turf tires killing grass #7
Drive only on the neighbor's lawn. He'll never know. Drive after dark!:shocked:
   / Turf tires killing grass #8
You said it. He drives ALL OVER His lawn. You drive in the same spot. I had a 770 and never saw where it had been cutting grass. Mind you, I never had a loader and come to think of it, the tires were not filled.
Make your roads wider and drive in varying positions.
   / Turf tires killing grass #9
Would I be correct?
Thanks
I don't think it is the weight of a 790 that is doing the damage. It might just be the type of grass/weeds that is a bit fragile. From your post photo, you have R4 tires not turf tires. If you are in 4 WD the front tires will be slightly spinning all the time. This could be the cause of the killing. I drive my 10000+(with FEL full of dirt) pound tractor several times over the yard hauling dirt and it doesn't kill my pasture grass lawn. I do try not to go more than a couple of trips in the same tracks though. It has R1 tires (loaded with water).
   / Turf tires killing grass #10
By the looks well travel and mostly shaded might be problem.
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
BY VALLEY INDUSTRIES 60 R22 823 LOT NUMBER 236 (A53084)
BY VALLEY...
2013 ISUZU NRR 20FT FLATBED TRUCK (A52576)
2013 ISUZU NRR...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
