Turf tires good in snow? YOU BET!
   / Turf tires good in snow? YOU BET! #1
wny770
WNY
Lots of old iron
To all the posters that clain turf tires are good in snow, you were right. I will eat my words. I've plowed with ag's, R-4's and turfs on the same tractor (NHT1510). BY FAR, turfs are best. Not as much tire slip in reverse as with R-4 tires. But what suprised me was how they gripped on blacktop. Mind you, I was only pushing about 6 inches or so, but NO wheel slip in 2wd on a slight uphill. I have to admit, I was impressed. Now, we just wait for a real snowfall.
   / Turf tires good in snow? YOU BET! #2
Flat w/down hill pushing?
I ran turfs for 14 plus years but w/chains,wet snow or even pack once needed that little extra bite.
   / Turf tires good in snow? YOU BET! #3
On my simplicity Conquest the front with no chains does not steer much.
Are you saying you use NO chains on the rear at all????
   / Turf tires good in snow? YOU BET! #4
That's good to know. I just purchased my first tractor and it had turf tires on the back and skid steer type on the front. The front were wore out and I replaced them but was not wanting replace the back if I did not have too. We are still waiting for snow here in Illinois also.
Mike
   / Turf tires good in snow? YOU BET! #5
I'm running turfs with chains. Without the chains, 6" was nothing, but once I got into 16" or more, things got way different. The chains provided the needed traction for bucking the big drifts. With the chains, it's nothing short of amazing what it will go through. Now, to be honest, I've never had R1s or R4s to compare performance, so this is really an incomplete assessment.
Joe
   / Turf tires good in snow? YOU BET! #6
Drive and snow type along with tractor will make a difference. My neighbor has a 35HP JD with Turfs and it will not do anything in the snow. He calls me to plow with my tractor and R1's. My tractor is only 28HP but will move 10 times the snow his will. He wants R1's but does not want to spring for new wheels and tires.
What I am saying is there is variables.
Chris
These are the Titan multi trac R-3 tires. No chains. I imagine a foot or two will be different, but with a blower I am not pushing as much as if I was plowing. I remember a few years ago blowing snow with my 62 HP Oliver... 16.9 x 38 rear rubber with an 84" 2 stage blower. You can't compare a tire over 5' weighing about a ton w/ballast with a little CUT tire, I understand that. But none the less, over the R-4's I had last year, for me, a big improvement. Who knows, maybe we'll get another 7 foot snowfall like we did in 2001? I sure hope not!!!:laughing:
   / Turf tires good in snow? YOU BET! #8
Once we get a good frozen base of snow/ice on the driveway the tires don't matter. Its the chains that make the difference....
   / Turf tires good in snow? YOU BET! #9
My BX has turfs also, without chains. Even in the deep snows that we had last season, it performed up to my expectations. I call "deep" about 12 inches around here. It's the wind drifts that make the FEL handy along with the RB. If there is ice, i think I'll just stay indoors since I don't plan on buying chains. Being retired and not "in business", gives one that luxury. I'm not against having chains (have them for my truck), but can get along fine without them on our relatively flat road. Yet, who can "snow blow" or "grade" ice........ regardless of the traction?:(
   / Turf tires good in snow? YOU BET! #10
I have a JD 2210 with both turfs and bars. I ran the turfs one winter and then switched to the bars the next year. No chains on either set, and 200 pounds of weights on the rear wheels plus a backblade which weighs ~300 lbs. FEL on the front.
While either tire works OK on my asphalt drive when plowing snow, I have found that when trying to drive through deep snow (for this little tractor, 18" or more) I can go right through it with the bars, but the turfs will give up quickly and get stuck. Since I frequently haul firewood from the back of my property to nearer the house, and cut a new path each time, the bars work much better. I have not noticed any lose of traction with the bars while plowing the driveway.......
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
ROLL OFF BOX (A53843)
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A54607)
2007 FREIGHTLINER...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
2012 VOLVO EC300DL EXCAVATOR (A51406)
2012 VOLVO EC300DL...
24FT Enclosed Trailer (A53424)
24FT Enclosed...
