Tires Turf tires for my FX28D?
   / Turf tires for my FX28D? #1
Anonymous Poster
Epic Contributor
I'm trying to locate rear turf tires for my new (to me) FX28D. The current rear tires are 12.4-26 (yes that is correct) bridgestone tires. I've got an e-mail into miller tire. Anyone know where to look and who to call?
   / Turf tires for my FX28D? #2
Bridgestone/Firestone makes a Turf and Field 13.6-16 R-3 for a 12" wide rim and an ANS 12.4-16 R-3 for a 10" wide rim.
<A target="_blank" HREF=http://www.firestoneag.com/tiredata/bias/bias.asp>Firestone Bias Tires</A>
Find a Firestone AG tire dealer and he/she can get them I suppose.
Jerry
   / Turf tires for my FX28D? #3
The closest dealer I saw was 67 miles from New Orleans in St. Gabriel
I'm not sure that those would fit my rims and maintain the rolling circumference for the 4wd. I'll try to call and see. I think the 12.4 indicates a 12 inch rim.
   / Turf tires for my FX28D? #5
I totally apologize..............I see now that the tire size was
12.4-26
Looks like you'll need to change rim sizes too, if you know the circumference if the tires, you could match something up.
That is the problem. If I change the rear rims, then won't I have to change the front?
   / Turf tires for my FX28D? #7
Not if you keep the rolloing circumference the same as it is now. The tractor doesn't care what tire or rim is on there, just keep the tires the same physical size, no matter what the rim center size is.
Sounds good, now I just have to figure out the circumference for my tires.
   / Turf tires for my FX28D? #9
put some wet paint on the tread........roll the tractor on a flat paved surface.........measure between 2 dots
Yeah, I know the trick, I was just hoping to avoid it. I was hoping someone knew some correct turf tires that would fit what I already have.
2005 Superior Trailers VT130 T/A Vacuum Trailer (A51692)
2005 Superior...
6x14 Double Axle Bumper Pull Trailer (A51572)
6x14 Double Axle...
CAT Skid Steer (A50322)
CAT Skid Steer...
2013 Bobcat E32 Mini Excavator (A51691)
2013 Bobcat E32...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
2025 New/Unused Wolverine 3 Point Quick Hitch (A51573)
2025 New/Unused...
