Tires turf tires and gear ratios...
   / turf tires and gear ratios... #1
blangham10
Lawrence
Yanmar YM 2820D and Kubota L2600 DT
I'm looking into converting to turfs or R4s on my YM 2820D. I've tried Hoye and they can't get them. Once I understand how to do the math I can start my search for the rims and tires. Any help on how to size them without wrecking the transmission would be greatly appreciated.:thumbsup:
   / turf tires and gear ratios... #2
Measure the diameter of the front & rear R4 tires presently on the machine.
Divide the rear diameter by the front diameter - this is the ratio you will need to match with the front & rear turfs.
   / turf tires and gear ratios... #3
The parts manual for my 2002d gives gear tooth numbers for the gears in the drop box. Simple math will give you the ratio if your manual has that information. You can then go to the forumula for calculating for correct tires.
I am supposing your 2820 has 12.4-26 on the back and 7-16 on the front. BKT tires gives RC as 3557mm (87.283") and 2217mm (87.283"). That equates to a 1.6044 ratio. Not all tire manufacture's maintain the same specs so don't take that as the for sure application.
Don't know if any of that will help or not.
Baby Grand--I currently have R1 ags and am wanting to change to either R4s or turfs. Thanks for the tip though!! Thats the kinda ciphering I can handle.
winston1-- You're correct on the rear tires but the fronts are 8-16. I'm confused by the conversion from mm-inches though. ["BKT tires gives RC as 3557mm (87.283") and 2217mm (87.283")"] The inch nums are the same?
   / turf tires and gear ratios... #6
Sorry about that, 3557mm (140.0394").
Do you have a parts manual and do you think the 8-16 is the correct tire for your tractor? Hoye shows 7-16 for your tractor?? Yanmar Tractor Tire Sizes
No problem... I'm not sure that the ones on my tractor are the right size tire. At this point, it wouldn't surprise me. I've been working on the cooling system and realized after removing the thermostat housing, it had no thermostat in it from the time I bought it 8yrs ago! I'm kinda scared to go in much deeper of what else could be missing!
Thanks for the link to hoyes tire page.
2015 Ford Transit 250 Cargo Van (A55852)
2015 Ford Transit...
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A54814)
2014 Peterbilt 384...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
1999 Southwind Fleetwood 34N 34ft Class A Motorhome (A55853)
1999 Southwind...
