Turf tire size for B7610
   / Turf tire size for B7610 #1
jas67
Platinum Member
Central PA
Kubota B7610 + Kubota G1800-S
I just got a B7610 that has R4's.
The rears are 12-16.5 (approx 33" outside dia.), and the fronts are 23x8.00x10 (aren't tire sizes confusing).
I might be able to buy a set of 33x12x15 turf tires on wheels (same outside dia. as my R4's), but was wondering what size turfs come from the factor when a B7610 was ordered with turfs. I know that with my B7100, the 8-16 R1's are 31" in dia, but for turfs, they use 29x12x15 (and a proportionally smaller dia. front tire).
I didn't see 33x12x15 as an available tire size in manual (which covers B7410,B7510, and B7610).
So, if anyone out there has a B7610 with turfs, please let me know the size of both front and rear tires.,
Thanks,
Jay
   / Turf tire size for B7610 #2
I think my turfs are 33X12.5X15 for the rears and 23X10X12 fronts I believe. I will check and get back to you.
   / Turf tire size for B7610 #3
My B2400, a series older but essentially the same tractor, uses 33x12.50x15NHS on rear and 23x8.5x12 on front. When I replaced the front tires, I ended up with Titan Multi-Trac CS 6plys. The 6 plys have worked out great with no flat tires. My Father In Law has the same tire in a 4ply, and has been plagued by flats until he Slimed the tires.
   / Turf tire size for B7610 #4
if you go with turfs get the heavy ply on the fronts. I loved the turfs on the 7510 that was until I went to lift something heavy. I had to run way heavy on the air preasure in order to keep the tires from squating. I always expected I would ruin the tires but never did. I went with r4s on the b3200 and so far am happy with them.
Rob
   / Turf tire size for B7610 #5
I was just out using the tractor in the rain and looked at the tire size the fronts are 23x8.5x12 not 10" wide like I had thought. So far the turfs have been ok. They spin in the dirt while using the FEL but othre than that no complaints. Good luck
   / Turf tire size for B7610 #6
Are your tires loaded? Take a lot to spin my loaded tires.. espcially if in 4wd...
   / Turf tire size for B7610 #7
No they are not loaded. Do you have both front and rear loaded? I have the kubota ballast box on the 3-pt with 400-500 pounds of rocks in it.
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
Ficklin Mod. 4500 Gravity Wagon (A50514)
Ficklin Mod. 4500...
2014 CATERPILLAR 740B OFF ROAD DUMP TRUCK (A51242)
2014 CATERPILLAR...
2005 Ford F-150 Ext. Cab Pickup Truck (A50323)
2005 Ford F-150...
1994 Alumatech Frameless Dump Trailer (A50514)
1994 Alumatech...
2011 Ford F-250 Omaha Service Truck (A50323)
2011 Ford F-250...
