Turf tire size for B7610
/ Turf tire size for B7610 #1
jas67
Central PA
Kubota B7610 + Kubota G1800-S
I just got a B7610 that has R4's.
The rears are 12-16.5 (approx 33" outside dia.), and the fronts are 23x8.00x10 (aren't tire sizes confusing).
I might be able to buy a set of 33x12x15 turf tires on wheels (same outside dia. as my R4's), but was wondering what size turfs come from the factor when a B7610 was ordered with turfs. I know that with my B7100, the 8-16 R1's are 31" in dia, but for turfs, they use 29x12x15 (and a proportionally smaller dia. front tire).
I didn't see 33x12x15 as an available tire size in manual (which covers B7410,B7510, and B7610).
So, if anyone out there has a B7610 with turfs, please let me know the size of both front and rear tires.,
Thanks,
Jay
/ Turf tire size for B7610 #3
My B2400, a series older but essentially the same tractor, uses 33x12.50x15NHS on rear and 23x8.5x12 on front. When I replaced the front tires, I ended up with Titan Multi-Trac CS 6plys. The 6 plys have worked out great with no flat tires. My Father In Law has the same tire in a 4ply, and has been plagued by flats until he Slimed the tires.
/ Turf tire size for B7610 #4
if you go with turfs get the heavy ply on the fronts. I loved the turfs on the 7510 that was until I went to lift something heavy. I had to run way heavy on the air preasure in order to keep the tires from squating. I always expected I would ruin the tires but never did. I went with r4s on the b3200 and so far am happy with them.
Rob
/ Turf tire size for B7610 #5
I was just out using the tractor in the rain and looked at the tire size the fronts are 23x8.5x12 not 10" wide like I had thought. So far the turfs have been ok. They spin in the dirt while using the FEL but othre than that no complaints. Good luck
/ Turf tire size for B7610 #6
Are your tires loaded? Take a lot to spin my loaded tires.. espcially if in 4wd...
/ Turf tire size for B7610 #7
No they are not loaded. Do you have both front and rear loaded? I have the kubota ballast box on the 3-pt with 400-500 pounds of rocks in it.
