Chuck,
I have had my Turf Special for around 2 years and have about 100 hours on it. I use it to Mow and also have a Leinbach posthole digger and a 4 ft grader blade. Mine also has the 302 loader which was about a $100 more than the smaller one so a no brainer.
I have not had even a hickup out of this tractor. A 10+ for reliability and quality. The Honda Accord of tractors. I plow snow in PA, fires right up in cold weather. Use the grader blade and go backward. Works great. You can destroy many things with this tractor and a grader blade...be careful.
The million dollar question. The mid mower. The mower is easy to adjust once you figure it out. Pull the pin and get a small hammer to gently tap the arm and piece of cake. Once you set it you won't ever change it. I had a ground engaging pto rear mower setup on a different tractor before this,and loved it. The mid mower, like everything has advantages and disadvantages. If ground is rough you can move fast with the suspended mower deck. No scalping is good. Disadvantage is you can't just back up to something and drop the deck. Kubota mower decks are not the cleanest cut. My John Deere mower leaves a much nicer cut, but can't move anywhere near as fast. Many have commented on the cut from Kubota.
This MM was a complete bear to remove at first. Here is the key. Find a farily steep hill, drop the bucket all the way down and lift the front of the tractor. Drop the front mower attachment, pull the pins on the back and use your foot to slide the deck sideways. Oh yeah, deck must stay on asphalt, concrete etc. Don't even turn the antiscapl wheels sideways. Takes about 1 minute to remove, 3 minutes to put on. PTO can be a pain if you move it from original postion after you take it off. You will be crawling under the back to do this. Any rear implement requires taking off the MM deck.
Tractor was heck of a buy. 4WD, HST, Mower deck and FEL for under $13K. If I had to do it over again is a tough call. I really like the
L2800 but a one stage pto, the
L3400 brings tears to my eyes everytime I see one, but more bucks. I can't see why a 7610 or 7800 instead of the 7510 as not much difference in size. A BX is too small and just as much coin. All in all for what it is the
B7510 Turf Special is a high quality, very versatile machine. I don't need anything bigger, just love the
L3400.
Hope this helps.
Mow
