Tires Turf or Industrial tires?
   / Turf or Industrial tires? #1
shop_rat45
Columbiaville, MI
New Holland TC30
I will be getting my tractor by Friday and I still have the opportunity to specify what tires I want on it. The tractor is a NH TC30 and it will be used for mowing, landscaping, plowing snow, and anything else I feel the need to do. So, which tires should I get? Turf or Industrial? I don't want to tear my grass up when mowing, so that is the only reason I am considering turf tires. All other uses, industrial tires would probably work better. So, how bad will the industrial tires tear up my lawn? (if at all)
Thanks for the info. I love this website already!!
Kris
   / Turf or Industrial tires? #2
Its GIVE and TAKE. You're just going to have to decide what is the most important to YOU and make a decision.
Turfs----best for mowing, but worst for digging, pulling, soft ground.
Industrials----good for mowing, but can rip it up very slightely if its wet and you turn as sharp as possible. They also pull, dig and have good traction in soft ground.
No you decide!
I'm VERY glad I got industrials instead of turfs, because the industrials really aren't that aggressive! They rarely tear anything up, and my a flood-plane on my river land.
   / Turf or Industrial tires? #3
I have been mowing with my TC30 for about 5 years now, with the R-4 industrial tires, and I have not torn up the lawn, unless it is unhealthy or new grouth, AND I have to turn real sharp. As long as it is fairly thick and green, you'll be all set. I also blow snow, on a driveway that is mainly a hill. I did get Valby ice chains for the rear tires, to help get wintertime traction. They work great! I also do the landscaping at my, and my mothers properties. You will be very impressed with what the little TC30 will do. I also have a NH757 subframe backhoe that I bought used, and it is also surprizing at what that will do as well. Have fun, and don't worry about your lawn with the industrial tires.
Daryle.
   / Turf or Industrial tires? #4
Industrials unless you plan on exclusively using the tractor to mow with. I have AG tires on mine and mow with them. They do tear up the lawn on turns, but only if I make sharp turns, or the ground is wet. The grass recovers fairly quickly though.
   / Turf or Industrial tires? #5
I put turfs on my JD2305 because I'm mostly mowing with it and my yard is new and not very compacted yet. I also need to make lots of sharp turns. I can see tire marks when its soft ( a day or two after a rain), but otherwise see nothing. I've also just pulled some 20'-30' tree sections out of the yard and up a steep bank while turning and had no slippage at all over bare dirt. That said, if your yard is established and compacted the R4s should be safe (but I've never used them).
   / Turf or Industrial tires? #6
Industrials (R-4's) and don't use 4wd to mow with (that will considerably lessen the binding of the front wheels)
turfs are ONLY good for mowing (or other work on turf)
   / Turf or Industrial tires? #7
I did moderate damage to my lawn with my L3130 on R4s.. mostly in areas where I passed repeatedly. But when the backhoe is attached it really peels back the turf.. especially in 4wd. I do a lot replanting in the spring after a project where I'm moving the big tractor on the turf a lot.
That being said.. turfs are worthless for loader work.. you might as well have slicks on there when driving into a pile.
My solution.. I bought a BX for mowing and light loader work..
R4 damage is directly proportional to the weight of the tractor.. if you're carrying a lot in the bucket and have it in 4wd.. those fronts are going to bite into the turf on corners.
I'd still go with the R4s if I was you. As long as you don't drive the same area over and over.. the turf should stand up to the mowing.
   / Turf or Industrial tires? #8
LoneCowboy said:
.....turfs are ONLY good for mowing (or other work on turf)
You haven't used them much to know, as I beg to differ...... :D
Turfs will work with any tire within the machine's capacity. This digging and scratching and bulldozing forwards and backwards with souped up enginuity doesn't count. A turf does all one could need, with one exception that you may be correct... plowing... But you may have never plowed with mules.... ;)
   / Turf or Industrial tires? #9
If I ever get turf tires again they will be 6 ply instead of 4 ply. I have had four flats in 180 hrs on the tack. All have been on the front tires.
   / Turf or Industrial tires? #10
I like my R4's, but like others have said, I take it out of 4wd when driving around on the grass. I have heard hear at TBN that neither are that great in the snow and ice, so I am looking for a good set of chains for this winter.
UNUSED KIVEL QUICK ATTACH TRAILER MOVER (A51248)
UNUSED KIVEL QUICK...
2023 Club Car Carryall 700 Utility Cart (A51691)
2023 Club Car...
BESTWAY LOT NUMBER 40 (A53084)
BESTWAY LOT NUMBER...
1984 ASPT 30ft Pole S/A Towable Trailer (A51692)
1984 ASPT 30ft...
1/4 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/4 '' Wolverine...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
