turf or industrial, that is the question! survey
   / turf or industrial, that is the question! survey #11
kch,
on the new 'Bota 7500 I just ordered, it would have added $100+/- if I had went w/ R4's vs R1's. Haven't priced independent of new pkg.
   / turf or industrial, that is the question! survey #12
Re: turf or industrial, that is the question! sur
kch
for the new 2910 the price diff. on r4's verses turfs it was only $20! thats right $20. from this my dealer called it a wash and gave me my choice, wich was r4's. as far as i have ever been told the price difference changes for every model of tractor.
   / turf or industrial, that is the question! survey #13
Hi,
You also need to look at the R4 tire you will be getting. For example, I was surprised that my B2910 Kubota came with 4 ply R4s, when I was expecting 6 ply. R4s up to 12 ply have been reported on various tractors. 4 ply R4s are clearly listed as what is supplied with the B2910, so I can't complain. I should have paid more attention I suppose...
Perhaps the higher the ply rating the higher the cost of the R4s, and hence the greater the price difference that is reported now and then.
I was expecting a heavy duty, puncture resistant R4s...but after my first flat ended up foam filling the fronts for $136 for the pair. Guess in the end things worked out for me.
At the moment I have 30 hours on my tractor, and only about two are grass cutting. I am happy with the R4s, but have noticed that they on occasion do mark the grass as I drive over it.
Bill in Pgh, PA...more or less...
   / turf or industrial, that is the question! survey #14
i have and like R4's. they are a great comprmise. there are days i wish i had ags, then there are days i wish i had turfs, then there ar days i wish i had ags with chains, get the drift? get the tire that will suit you best for most of your needs, for me r4 was the way to go.
   / turf or industrial, that is the question! survey #15
I use ags on all of my tractors. I mow lawn, move dirt, plow snow,grade the driveway, rototilling, etc. I notice slight scuffing while mowing if the yard is really soft. I think the other thing you have to consider is that you mow differently with a rear mounted finish mower than you do with a belly mower. I don't try to circle trees tightly any more I just catch what I missed on another pass. Much less tight turning which causes the scuffing on the lawn. I wouldn't trade my 6' finish mower and a little scuffing to go back to 42" and a lawn tractor for anything.
nick
   / turf or industrial, that is the question! survey #16
kch, on my NH 1920 I currently have turf tires. One thing to consider is most turf tires are smaller in diameter than R-4s (and ags). There is a 6 inch difference 43" for turfs, 49" for R-4s that corresponds in a 3 inch loss of ground clearance on the NH 1920. With a sub frame mounted backhoe that 3 inches sometimes means the difference between getting hung up on objects or not. Just my thoughts.
Bill C
   / turf or industrial, that is the question! survey #17
I use my tractor alot as a digging tlb and the greater load capacity and punture resitence of the R4s decided it for me. When I do mow the R4s are ok as long as I take it easy.
Interesting........ so you use turf's only because they are smaller in hight? So I am assuming when you use the backhoe you don't move or need traction so besides the lower hight is there more benefits for having the turf's? I also like the fact that they make the entire tractor smaller.
I guess there are normal turf's and a exra wide truf's. New Holland calls them galaxy's I think. Does anyone have any information or experience with the exra wide turf's?
   / turf or industrial, that is the question! survey #19
kch
I have the Galaxy o.s. turf tires on Kubota L4610, all 4 loaded w/ Rimguard. I'm happy with them on grass and in the dirt. They work in snow as long as you plow where you're going, don't drive up on deep snow!
regards
Mutt
   / turf or industrial, that is the question! survey #20
I have R4s and was surprised to find when the tractor was delivered last month, or rather when I got a front puncture a few days later, that on the Kubota B2910 the standard R4s are apparently only 4 ply, front and back.
So if you are looking for the puncture resistance of a higher ply tire, check what you are getting...I assumbed R4s were all 6 ply and was surprised.
As far as grass cutting goes, my R4s seems OK, although I don't have a plush lawn by any means. I got my fronts foam filled and they still seem to do OK on the grass. That is mowing with a RFM and with the loader removed.
Bill in Pgh, PA
SAMSUNG SMART REFRIGERATOR (A54757)
SAMSUNG SMART...
2014 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A53422)
2014 Chevrolet...
2016 Mitsubishi Fuso FEC52S Cab and Chassis Truck (A55852)
2016 Mitsubishi...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
2011 Chevrolet Equinox SUV (A53424)
2011 Chevrolet...
9202 (A50322)
9202 (A50322)
