TurboSaw on JD 4300
   / TurboSaw on JD 4300 #34
My 4300 HST Owner's Manual page 162 says PTO HP is 25.5
   / TurboSaw on JD 4300 #35
That's a real cool tool, Beenthere!!
Watching the video, it didn't sound like you were turning anywhere near PTO RPM. Was it, or did you set RPM lower then PTO RPM?
Roy, you are correct. I don't run the PTO at 540 RPM, more like 375 or 400.
Might cut a bit faster at 540 but it also can cause more flying chips and stress on parts if the tree happens to lean onto the blade. A few times when cutting down stumps to ground level I've had a chunk of wood get between the top of the blade and the frame.. squeals a bit then. I added a mesh screen between the saw blade and me (the operator). Fewer chips on me.
I get more pleased with it the more I use it. With the iMatch, I can attach it, hook the PTO up, and be off cutting in a few minutes.
Cleaned the stumps off an acre of land a neighbor had cleared of small hardwood trees (making some oak savanna) and wanted to mow there. He was impressed with what could be done.
   / TurboSaw on JD 4300 #37
Just saw this in monthly Fastline Catalog.
TreeHog 40
They have hydraulic cutter wheel extension and hydraulic push bar so, you need at least 2 remotes.
They offer versions with 40” and 48” cutter wheels.
   / TurboSaw on JD 4300 #38
Man I could really use one of those. I have several sawmill blades that I think are 36" would love to make one.
I like that turbosaw.. as well, the treehog may do the job too.
Keep us posted on the sawmill blade build. :thumbsup:
   / TurboSaw on JD 4300 #40
Probably one of those never get done projects. I've been ripping them out with chains and the backhoe. Slow and messy but it's been _or king.
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A55973)
2013 Chevrolet...
2015 DRAGON 130BBL VACUUM TRAILER (A58214)
2015 DRAGON 130BBL...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
Auger Drill Bit (A56857)
Auger Drill Bit...
2016 GENIE Z80/60 TELESCOPIC BOOM LIFT (A52709)
2016 GENIE Z80/60...
Enmark Z Spray (A53316)
Enmark Z Spray...
