sd455dan
Elite Member
- Joined
- Oct 23, 2012
- Messages
- 4,797
- Location
- North Idaho
- Tractor
- Rhino 554, Ford 550 TLB (JD X500, MTD, Gilson riding mowers) Ford 3000-Sold
We will post more detail later, but I can give an overview of what we accomplished so far.
The GT15 turbo clone is installed. However, we are only getting 3 PSI boost max, typically it is closer to 2.5 PSI boost. This is from an oil-filled pressure sensor off the intake manifold (0-15 psi, after the turbo). The wastegate never activates, meaning we never hit 4 PSI
In terms of performance I brush-hogged the same deep grass, this time in 3rd gear without any drop in engine RPM. I could see the boost pressure rise up to 2.5PSI when I entered the deeper brush, and instead of having to shift down to 2nd gear I could stay in 3rd the entire time.
We have an engine exhaust temperature probe in the exhaust manifold prior to the turbo.
In the heaviest mowing I saw 500F, but typically it was around 400-420F with 375F in lighter grass.
The temperature was 180F max after 45 minutes of brush-hogging. We discovered the OEM thermostat was "stuck", after un-sticking it we measured 170-180F while mowing.
The high-flow thermostat did not allow the engine to warm up.... it stayed at 147F max with that thermostat in. Though we only rev'ed it up and didn't drive or mow with it while testing that high-flow thermostat.
We are still thinking about why our max boost is 3 PSI
- one small leak in the pressure sensor hose was uncovered and fixed (minor improvement), other pressure leaks?
- fuel adjustments - ****** fuel timing? Typically as boost pressure rises on a diesel you ****** up to 24 degrees before TDC
- other?
We will update with video's and pictures later, it was a busy weekend getting it all plumbed in and ready for testing.
Sounds like you are still getting a net improvement in performance:thumbsup: even with that small amount of boost.
Have you already cranked up the fuel screw?
Sounds like progress is being made and thanks for the update
