Turbo on a 1040
   / Turbo on a 1040 #1
straightlining1
Auckland
John Deere 1040
Hi, Im thinking about installing a turbo on my John Deere 1040. Has any done this? Will the engine handle a wee bit of boost? Mounting it etc shouldnt be an issue, but not sure on the fuel injecters and pump. Any ideas?
Thanks
   / Turbo on a 1040
It doesnt do farm work, just tows my boat to the beach:thumbsup:
   / Turbo on a 1040 #3
I put one on my Ford 1720 and I work it!
Very happy with the results.
No need for injectors, just turn the pump up a bit.
90cummins
   / Turbo on a 1040
What was the turbo off? Much increase in proformance? Got any pics?
   / Turbo on a 1040 #5
It is a waste gated Garrett GT1752 off a Saab.
Huge increase in HP. Originally 27 HP now 35 to 40 based on how it blows snow and hauls a 6000lb trailer of hardwood.
I posted photos in the review section at the top of page in the Ford 1720 section.
It'll get your boat to the beach!!!
90cummins
   / Turbo on a 1040
I like alot. Would your motor be 1.5 to 2 itres in size? Installation looks clean
   / Turbo on a 1040 #7
Its 1.5 liters. I turned the fuel rate up & set the top speed to 2900rpm. I also wired the waste gate closed.
I run a max of 10 psi boost (intermittent) 5lbs steady state.
The GT 1752 is ideal because the compressor & exhaust turbine housings are clock able, so you can turn them for alignment.
This is one of the best mods I ever did. The tractor was perfect in every respect except for power, now it performs the way I want it to.
90cummins
   / Turbo on a 1040 #8
How 'bout some pictures of that 1720? I would concider puting a turbo on my jd 3005 when the warrentee runs out. I wonder if the internals of the yanmar motor can handle the boost... how has you ford handled the extra power? I put an aftermarket turbo on my chevy 6.2 n/a diesel years ago but put new headgaskets and head bolts at that time.
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
40ft 2-Door Shipping Container (A55851)
40ft 2-Door...
2010 Ford F-750 Stellar 10621 10,000LB 5 Ton Crane Mechanics Truck (A51692)
2010 Ford F-750...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
UNUSED JCT DB500 DUSTLESS BLASTER (A57193)
UNUSED JCT DB500...
2016 Freightliner M2 106 Altec AM50 50ft. Bucket Truck (A55852)
2016 Freightliner...
