Turbo on a 1040
   / Turbo on a 1040 #1
straightlining1
Auckland
John Deere 1040
Hi, Im thinking about installing a turbo on my John Deere 1040. Has any done this? Will the engine handle a wee bit of boost? Mounting it etc shouldnt be an issue, but not sure on the fuel injecters and pump. Any ideas?
   / Turbo on a 1040
It doesnt do farm work, just tows my boat to the beach:thumbsup:
   / Turbo on a 1040 #3
I put one on my Ford 1720 and I work it!
Very happy with the results.
No need for injectors, just turn the pump up a bit.
90cummins
   / Turbo on a 1040
What was the turbo off? Much increase in proformance? Got any pics?
   / Turbo on a 1040 #5
It is a waste gated Garrett GT1752 off a Saab.
Huge increase in HP. Originally 27 HP now 35 to 40 based on how it blows snow and hauls a 6000lb trailer of hardwood.
I posted photos in the review section at the top of page in the Ford 1720 section.
It'll get your boat to the beach!!!
90cummins
   / Turbo on a 1040
I like alot. Would your motor be 1.5 to 2 itres in size? Installation looks clean
   / Turbo on a 1040 #7
Its 1.5 liters. I turned the fuel rate up & set the top speed to 2900rpm. I also wired the waste gate closed.
I run a max of 10 psi boost (intermittent) 5lbs steady state.
The GT 1752 is ideal because the compressor & exhaust turbine housings are clock able, so you can turn them for alignment.
This is one of the best mods I ever did. The tractor was perfect in every respect except for power, now it performs the way I want it to.
90cummins
   / Turbo on a 1040 #8
How 'bout some pictures of that 1720? I would concider puting a turbo on my jd 3005 when the warrentee runs out. I wonder if the internals of the yanmar motor can handle the boost... how has you ford handled the extra power? I put an aftermarket turbo on my chevy 6.2 n/a diesel years ago but put new headgaskets and head bolts at that time.
2014 Ford Escape (A50324)
2014 Ford Escape...
43016 (A51691)
43016 (A51691)
2015 Ford F-550 Chassis Truck (A50323)
2015 Ford F-550...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50774)
ALL ITEMS NOT...
2006 Ford Fusion SE Sedan (A51694)
2006 Ford Fusion...
AGT QH12 Mini Excavator (A50322)
AGT QH12 Mini...
