Turbo charger question
/ Turbo charger question #1
Kelly11736
I would like to put a turbo charger on a Case Super K backhoe. Someone told me the pistons, etc had to be changed also. Is this correct? Got any ideas where to buy a used T-charger? Any thoughts in general??
/ Turbo charger question #2
I know that this isn't the answer that you are looking for, but. You may or may not need to change the pistons. Some heavy duty applications, such as diesels, use the same piston in turbocharged and non-turbocharged applications. Have your parts man check for the piston in both applications and see if the part number is the same. Having said all of that, given the diesel piston design, you could possibly have a low pressure system installed even with non-turbo pistons.
/ Turbo charger question #3
When you add turbo, usually you don't reassemble engine, and replace parts. Just need to change air and exhaust manifold. Engines with turbo added usually put out less hp than similar turbo engines what are factory done. Key reason to add turbo is to increase max torque and elasticity of engine curve and slightly increase max power.
Don't know for your Case.
/ Turbo charger question #4
From what I understand alot of the smaller tractors coming out w/ turbos' are on there as much for emissions control as anything - burns cleaner & more efficiently w/ turbo. As for your question - I don't think I can add anything that has'nt been said already.
/ Turbo charger question #5
Kelly, Does your tractor manufacture offer a turbo model? If not you may find an after market company that sells a kit, But I would never buy a used turbo unless it was certified good! The turbo is the most important part and you must know that the one your going to use is good , bearings good , balanced ,oil cooled, etc.
You only want to do this once may as well do it right, Just my opinion... Also is your power way down as is? or do you just want more?Injectors clean? Turbo may reqiure larger injectors to prevent a lean conditon(heat problem).
There is more to it than just bolting a blow drier on top. /forums/images/graemlins/shocked.gif /forums/images/graemlins/wink.gif
/ Turbo charger question #7
dump about 10% gasoline in the tank and watch the stack glow /forums/images/graemlins/laugh.gif
/ Turbo charger question #8
" Turbo may reqiure larger injectors to prevent a lean conditon(heat problem)."
The turbo is going to need larger injectors to produce more power. Added air doesn't do anything in itself, it allows you to burn more fuel which is where you get the added power. Less fuel means less heat in a diesel, it will run cooler if you add a turbo and don't uprate the injectors.
/ Turbo charger question #9
Turbos work best at steady state RPM. No lag. The engine can operate very efficiently.
The engine/turbo combination should be designed as a unit for proper boost pressures and cooling.
For real power addittion a supercharger is ideal and responds to variable RPM.
Egon
/ Turbo charger question #10
Welcome Kelly, I have to agree with 5030, if you want instant power and lots of it, do the propane thing. I've heard you can get about 800 horsepower out of a 7.3 Stroker like that. Fill out your profile so we know what you have. I thought about the propane for my TC35, but 300 horsepower seemed a bit much for pushing snow or dirt. I'm not serious about this, I hope you know, but in Mich. most of us can be real smarta&@$ when we want. /forums/images/graemlins/cool.gif
/ Turbo charger question #11
Between the Ag industry and the industrial there might be a set up that would virtually bolt on as far as the externals. Many turbo'd engines do offer different pistons as well as jets of oil that spray the bottoms of the pistons to help with the cooling of them do to the increased heat. With the normal operation of a TLB there is not any extended times that Ifeel it would be needed as they aren't like a dozer or ag tractor that often would be calling on the boost for power for extended times vs the short intervals that a TLB might be under load.
Thanks to all who took the time to give me some answers! It seems that the consensus is to "Not" put a turbo on an engine that did not come from the factory with one. One suggestion is to put a "supercharger" instead. How complicated is this? What's the difference? Cost? Are these readily available? Thanks again! I appreciate it.
/ Turbo charger question #13
Turbochargers are exhaust driven. Superchargers are driven off the crankshaft via belts or gears. The blowers you see sitting on the tops of drag racers are superchargers.
A few years ago there was a supercharger kit you could get to add to your car. It consisted of a blower about the size of an alternator and the brackets to mount it to your engine. It was belt driven just like the alternator. After mounting, you mounted flexible pipe to get the pressurized air to the carb and the supplied filter was mounted on the inner fender to filter air before it went into the blower.
I don't think they caught on and am not sure if anything like that is still available. But it was a good idea for getting lots of fresh air into the engine for combustion.
/ Turbo charger question #14
You can still get the car superchargers. In fact, the same company that supplied the supercharger for the 50's T-Birds is still in business. Paxton
/ Turbo charger question #15
Ah yes.............Paxton Superchargers.
I had forgotten the name.
/ Turbo charger question #16
</font><font color="blue" class="small">( " Turbo may reqiure larger injectors to prevent a lean conditon(heat problem)."
)</font>
bgott has it correct. You need more fuel to get the extra power.
But, there may be some confusion as to the difference between gasoline and Diesel engine injectors.
On gasoline fuel injected engines you need to increase the size of the injectors to get more fuel in the intake manifold. On a hopped up gas car you run out of time to squirt in additional fuel with the stock injectors. You put higher capacity injectors on and the fuel volume per period of time goes up. Thus, taking advantage of the hop-up equipment (or supercharger/turbo). The gas car engine computer measures the exhaust gasses for the correct air/fuel ratio and adjusts the duration of the fuel pulse to keep the air/fuel ratio correct--no rich, no lean mixtures, just the 14:1 (??) ideal ratio. The throttle controls the amount of air going into the engine--the computer controls the fuel.
Diesel engines always have an excess of air to fuel. Thus, they always run "lean" to some degree. At idle a Diesel may run at better than a 50:1 air to fuel ratio, under power it will still likely be greater than 20:1 air to fuel ratio. This is why Diesels are always more efficient than gas engines. The throttle/governor on a Diesel controls the fuel, air is unlimited and is what ever is pumped (sucked) by the engine. [Although some Diesel engine shut-offs cut off the air supply to stop the motor.]
You may not need bigger injectors to get more fuel into a Diesel. You get more fuel by changing the injector pump settings. If the injectors will handle the increased volume of fuel, you probably won't have to change them. If you do change them it would be likely to get a different spray pattern to better handle the [effective] increased compression ratio that results from the turbocharger.
I believe Case has a turbo version of your tractor, or close anyway. The best bet would be to get a complete pull-off set of turbo, plumbing, manifolds and injection pump (and maybe intercooler?) from a wrecking yard. If Case does have this, check the parts catalog for a difference between the engine oil pump for both versions. A fair volume of engine oil is used to cool/lubricate the turbo. There may be a bigger oil pump on the turbo motor.
Dave
20ft Shipping Container (A61166)
20ft Shipping...
Informational Lot - Financing (A63688)
Informational Lot...
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
KBH Tender (A63118)
KBH Tender (A63118)
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
INOP/NON-RUNNING 2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL8DL188002 (A61165)
INOP/NON-RUNNING...
