Tundra vs. Chevy
   / Tundra vs. Chevy #131
I don't understand why anyone would want a "heavy half-ton". Why not just buy a 3/4 ton and call it a day? If the eco-boost does as well as Ford thinks it does perhaps they will put it in a 3/4 ton as an option? If they want to keep it in the 150 family then I can understand the "heavy half-ton". As far as towing, I've done more than my fair share. That was impressive Eric. The majority of my towing was with a 10K fifth wheel camper in the mountains of NC. I would like to see what an eco-boost would do towing that TYPE of load with 7% grades and switch backs in the heat of July. Still impressive though.
It would do fine. I have a 7% grade for 6 miles next to my marina. My 2012 EB with 3.73 gears eats it up.
As for the 3/4 ton thing I have had two. I can't understand why anyone would want a 3/4 ton when a 1 ton SRW is much more capable. The difference between a F250 and F350 is only $600.
The HD 1/2 ton trucks of today are more truck than the gas 3/4 ton trucks of just a dozen years ago. I know because I have had both.
Chris
   / Tundra vs. Chevy #132
If I am not mistaken the spring packs are the difference in F350 vs F250. Running gear, frame, brakes, etc. are the same. You are correct Diamondpilot for the difference $600 ain't much.
   / Tundra vs. Chevy #133
The maintenance issues, and increased running costs are why a person would prefer a lighter truck over a heavier truck.
On hills and grades (and I have nothing approaching a 7% grade) the truck downshifts to fifth and fourth.
When Ford first debuted the ecoboost F150, testing folks quickly hooked it up to heavy junk and towed it in 100 degree F temps up and over the 12 mile, 5% grade of Davis Dam. The ecoboost performed without flaw. Here is a 2015 comparison.
   / Tundra vs. Chevy #134
It's a little more than just springs. Tires and wheels are also bigger.
Chris
   / Tundra vs. Chevy #135
I have seen and read a few tests of the three competitors. I drove the 2015 Silverado 5.3 and the Ford 3.5 Ecoboost. Both had max tow options and max payload options and were LTZ/Lariat. The F150 also had FX4. On the GM products the Z71 is not available with the max tow option.
I preferred driving the Chevy as it was more car like and the Ford more truck like. However, the Ford had noticeably more acceleration in any circumstance. Both were rated for similar towing and carrying capacities. And the ford was ~ 10% more expensive, optioned similarly.
Since my heavy towing will not be often, I would consider a new heavy 1/2 ton due to the increased, unloaded fuel mileage as it could be a daily driver also. And I would have to have it built for me as my options are not available anywhere in a currently built truck, from GMC/Chevy or Ford.
Or I will consider a 2006 - 2010ish diesel 3/4 ton, lowish mileage Ram or Duramax, as a more limited use vehicle. I really like diesels... As mentioned previously, I drove a 2006 Ford 6.0 diesel and really enjoyed it. But I would need to get a large price cut on one due to the poor reliability of the 6.0 and those do not seem to be available in my area. And any 6.0 that has ARP head bolts and EGR delete are priced at the top end of their range. So it is a no brainer for me to bypass the Ford diesels.
Decisons, decisions. But a gas 3/4 ton in not in my future.
   / Tundra vs. Chevy #136
My father had a 6.0also. It only went for 3months at a time. He loved it but couldn't keep it running. It would out do any other truck their was. Way more powerful then his now Duramax. But because of one motor don't go hating on Ford diesels. The new ones we have heard are good trucks. So are all the 7.3 diesels. Think about it tho. Ford has always tried to go bigger and better. They were making diesels beck in the 80s when Chevy/gmc wasn't
   / Tundra vs. Chevy #139
6.2 was available back in the day I think. We even had an old 80's caprice with a diesel.
   / Tundra vs. Chevy #140
Love the guinea photobomb in the bottom right corner
UNSUED AGT MX-MRT14 STAND ON SKID STEER (A51243)
UNSUED AGT...
Livestock Stall Fan Cage (A50515)
Livestock Stall...
2023 Electric Intimidator (A50514)
2023 Electric...
2013 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2013 Ford F-550...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2019 Ford F-150...
Electric Forklift Pallet (A50322)
Electric Forklift...
