Tuffy rebuild
/ Tuffy rebuild #1
dstig1
Super Member
W Wisc
Kubota L5240 HSTC, JD X738 Mower, (Kubota L3130 HST - sold)
We got my MIL's old Troy Bilt Tuffy after she passed a few years back and I am getting around to dealing with it now. Carb needs help, no surprise, so will probably just replace. But here is the main question. All gear oil leaked out due to a couple bad seals on the wheel and tine axles. I have pulled those 4 seals (wasn't easy) and find that the shafts are scored in spots (one each). Replacement shaft seems possible on wheels but for $100 and the tine shaft I am unsure as there is some sort of "kit" for a whopping $300 but no idea what is in it as they give no details on the supplier sites I have looked on. By the time I replace both of those shafts, seals and a carb I might as well buy new with how much it will cost.
If I just clean these up with emery cloth does it have any chance of sealing again? I'm guessing poeple will want pics to really know so I will go grab some here shortly and post those up. At least one spot had a pretty decent gouge in it. Any methods to fill that will work and not destroy the shafts? I could try TIG build-up but always worry about warp with welding on a shaft.
/ Tuffy rebuild
/ Tuffy rebuild #3
speedy sleeves could work for you ---- I would just throw some weld on it and turn it down on the lathe. ---worked on case reverse idler shaft that was cut deep, so it can be done ---- just use enough heat to make decent weld. Some guys say high heat and move fast, I never tried that.
Still have my old tuffy here, only use him to cultivate between cabbage and tomato plants. Horse goes between the rows.
/ Tuffy rebuild #4
Switch from gear oil to grease in the gearcase. What I did, I had a leaker too. Filled the gearcase with chassis grease. Issue solved.
/ Tuffy rebuild #5
Sorry to say it but based on my experience I would not spend much money on lightweight tiller.
Perhaps the shaft can still be cleaned up with a fine wet sanding paper, after removing the heavy rust - I think it's worth trying it.
Here is my personal experience:
I bought this 5.5 hp Pony ProLine new back in year 2002 and used it for around 18 years it but was often struggling because it had only one ground speed (which was too fast most of the time), and not enough mass to keep it from launching fast forward when the tines would grab something hard like deep down packed clay for example.
It was often a struggle so I ended up using my tractor with a 48 inch 3 pt tiller.
I sold the Pony at a pretty good price and was glad to get rid of it.
Two years ago I finally bought this used 6 hp Horse model for $200 and cleaned up carburetor, installed a new fuel shutoff valve, fuel filter, belts and also replaced all four leaky shaft oil seals.
What a difference!
No more launching forward, if fact it has never done it so far and it has two speed transmission which is great.
I just wish I had bought the Horse model in the first place.
The Pony may work fine for some people ("the city folks" like my old boss used to say!), but no one will never again see me using one of those!
Not sure of differences between Tuffy and Pony, but they look similar - maybe someone here can educate us?
/ Tuffy rebuild #8
I have a 29 year old Horse I just RE powered with a GX270 8.5hp Honda. The old Kohler had the coil go bad and the kickback ruined the recoil starter before I was able to figure it out, the recoil is not serviced by Kohler anymore for the M8T. Well I had a tine shaft leak and the shaft was rough so I used a speedi-sleeve. She’s good as new, maybe better, now
/ Tuffy rebuild #9
It sure looks like new!
/ Tuffy rebuild #10
I noticed when I had it apart the depth drag bar was worn down almost through to the rear bolt hole. I had some hard surface electrodes so with my old Lincoln Idealarc250 I built it all back up and hard faced it. Good for another 29 years now
/ Tuffy rebuild
Wow that thing looks like new! How did you keep the label from wearing away with 30 yrs of use? That's just crazy! And yes the Pony model you show is identical, probably just newer. I think this one is 1998 vintage.
So I got it apart all the way. The wheel shaft looks pretty good and cleaned up with some emery cloth but the tine shaft looks pretty chewed up (to the right of the snap ring groove in the pics). The easy route will be to just replace this shaft, as it is $80 and that is not too crazy. I'll have to look into speedy sleeves as I have not heard of them before. I don't have a lathe but have a friend who is an ex-machinist that is well-equipped. I don't want to put much money into it but we did get it "free" and for what we need it for, it fits the bill. The small garden area is terraced due to our steep hillside and no way to get my tractor into it safely as it is way too big for that. We just don't have much open space for gardens here.
I've got a new carb coming next week and want to verify the motor works before I sink any more money into it. If it powers up and runs OK, then I'll get the rest of the parts. If it becomes not worth it, then I will probably just rent a tiller once a year to prep the garden or something.
/ Tuffy rebuild #12
I babied it for all those years, kept it clean and waxed in the shed when not in use.
Take your shaft to a bearing supply house and they can fix you up with a sleeve. They aren’t cheap but are a cheaper alternative to building up and turning it down
/ Tuffy rebuild #13
Tuffy is a bit smaller that pony and is excellent for cultivating around plants,----small light, narrow, and easy to use!
/ Tuffy rebuild #14
Yes. it is and exactly what I use mine for. Other than the leaky axle seals, been a good little tiller and it was free, found it in a dumpster. Tossed the oil burning Tecumseh and installed a 99 buck HF pred motor
Filled my gearcase with synthetic chassis grease 2 years ago, all good now.
Best attachment I got was the Ardisam Hiller / Furrower attachment for the Cub for planting potatoes.
/ Tuffy rebuild
Figured I should wrap this up....
Well I ordered a bunch of parts from 2 places - partly due to cost, partly due to stated availability. Well the one place sent their stuff promptly but the other place was waiting on 2 items to be able to ship - 1 was just a simple o-ring for the oil filler cap but the other was the shaft for the tiller tines. O-ring I can find but the shaft was first listed as 2-10 days...then 2 more weeks...then 2 more weeks... then it said something like "we don't know when these will be back in stock". Welll sheeeeiiit. So I called and said cancel the back ordered items and send the rest. Pulled an o-ring froma kit we have at work, so no biggie but the shaft was another issue.
I asked a friend who is a former machinist who knows his way around tools and also HAS the right tools (lathe and Bridgeport in this case) if he could make me the shaft. It is a simple shaft - 2 grooves for snap rings, 2 holes for the bolts holding the tine assemblies and one woodruff key slot in the middle for the drive gear. The woodruff key is the only part of this that is a bit challenging, but only if you don't have the right cutter, but he did. A chunk of 1" CRS and he zipped it out with me watching like an idiot in an hour or two. Then my 2nd batch of parts showed up and I started to figure out how to put it together. It's a bit of a puzzle. But as I started that I was looking at some parts that I had not closely inspected before and said, "ya know, I should get some new bits here" and remake that other shaft if I am going to "do this once, do it right"... So back to my friend's place with another bar of 1" CRS and the other shaft was done too. Almost the same but longer and 2 more grooves to turn. So we banged that out in an hour or two and the rest of the parts showed up, so it was reassembly time!
Mostly got it together last Sun but just finished it up tonight and took it for a test run. It works! Yeah it's a bit of a lightweight but I think it did OK for our small garden and should do the trick. So here's a couple photos. One of the new shafts next to the old ones, and the Tiller all complete and put away after the first run tonight.
Thanks for the help guys!
-Dave
/ Tuffy rebuild #16
Looks good and it's great to have a friend like that!
I have not yet given up on getting a used milling machine but....
/ Tuffy rebuild #17
Not many neighbor machinists left anymore. Not near me at least!
/ Tuffy rebuild
Well I also had to put a new engine on it, and I tend to try to do things "right" even though it is more expensive and slower so I just ended up rebuilding it all (mainly seals and bushings, other than the motor). In part it was a hassle that I probably didn't have time for right now, but it also allowed me to stall on tilling my wife's garden :D
/ Tuffy rebuild #20
I like your style. You can stall them so long then they get pizzed that leads to another area that you can’t till. Lol
2017 Bobcat T770 Compact Track Loader (A61307)
2017 Bobcat T770...
2015 Case TR320 (A60462)
2015 Case TR320...
SKLP SK-HJ6 40' 6 Section Storage Shelves (A60463)
SKLP SK-HJ6 40' 6...
2015 John Deere 3038E (A60462)
2015 John Deere...
84''Skid steer bucket (A61567)
84''Skid steer...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
