TUFFY 5 BRUSH HOG BROKEN BLADE
/ TUFFY 5 BRUSH HOG BROKEN BLADE #1
jb112454
Prague OK
2001 Kioti DK35
Does anyone know where I can get a new set of blades for my Tuffy 5 foot brush hog? I think its a cheap version of a Rhino. And I also think they are not made any longer. thanks /forums/images/graemlins/smile.gif
/ TUFFY 5 BRUSH HOG BROKEN BLADE #2
I can tell you to watch how high you lift it. It will strip the drive line shaft female end right now if you lift it up against the low bar on those models. T modification of the tirangle shaped models give way more clearance for the deck to come up and not push the center shaft into a solid immoveable object.
Sorry I havent gotten as far sas new blades yet
/ TUFFY 5 BRUSH HOG BROKEN BLADE #3
Tractor supply sells mower blades. Take one of your old ones (unbroken if possible) and compare bolt hole size and length. As long as the bolt hole is the same and the length is not too long the blades should work.
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
2016 Ford F-550 Flatbed Truck, VIN # 1FD0W5HT7GEC46417 (A65563)
2016 Ford F-550...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2014 RETESA 210BBL CRUDE TRAILER W/ PUMP (A65643)
2014 RETESA 210BBL...
SKID STEER VIBRATORY ROLLER (A62613)
SKID STEER...
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A61568)
2019 Ford F-350...
