Tuff Torq K46 repair
/ Tuff Torq K46 repair #1
JDL120
West Bend,WI
John Deer L120
I recently purchased the parts from to rebuild my K46 Transmission. After working on it, I cannot turn both axles the same direction at the same time while the tranny is in the "free state" position. That is, I have moved the lever to where the axle should be able to spin both directions (as if to be pushing or pulling the tractor). I have compared my assembly with photos and diagrams of how it should go back together,and appears to be correct.With the case open,I can move the center assembly of gears by hand one direction, and it does indeed move both axles as well as the top input shaft, but it will not rotate the other direction. It seems to "lock" against the differential. Can you offer any suggestions for what I may have done wrong please?
