Tubeless substituted for tubes tires.
   / Tubeless substituted for tubes tires. #1
davidhoffman 5
RAFB, GA
Kubota
Is it possible to use tubeless tires on a wheel designed for tubed tires? If so, is it as safe as using wheel designed for tubeless tires? I have seen the other threads about foam filling, so I will be considering that option also.
   / Tubeless substituted for tubes tires. #2
I have used tubeless tires on tube type wheel without any problems as long as the tubeless tire is wider than the original tube type tire. If they aren't it is easy to break the bead loose. Especially if the air pressure is a little low.
How much wider? Is it a percentage of tread width or a fixed amount?
   / Tubeless substituted for tubes tires. #4
For 7.50-16 I have used a 245/70-16 without any problem. I usually get used truck tires.
   / Tubeless substituted for tubes tires. #5
most wheels will work either way
   / Tubeless substituted for tubes tires. #6
I have some older wagons with tube type wheels & the wheels don't have the dip for the bead to lock into. That is why the tubeless tires need to be wider.
Thanks to all. Stayed with the tube. Bought new tube and new tire.
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2013 ISUZU NPR STAKE BODY TRUCK (A52577)
2013 ISUZU NPR...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2018 DODGE RAM 3500 (A52472)
2018 DODGE RAM...
2008 FORD F550 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F550 XL...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
