Tubeless substituted for tubes tires.
   / Tubeless substituted for tubes tires. #1
davidhoffman 5
RAFB, GA
Kubota
Is it possible to use tubeless tires on a wheel designed for tubed tires? If so, is it as safe as using wheel designed for tubeless tires? I have seen the other threads about foam filling, so I will be considering that option also.
   / Tubeless substituted for tubes tires. #2
I have used tubeless tires on tube type wheel without any problems as long as the tubeless tire is wider than the original tube type tire. If they aren't it is easy to break the bead loose. Especially if the air pressure is a little low.
How much wider? Is it a percentage of tread width or a fixed amount?
   / Tubeless substituted for tubes tires. #4
For 7.50-16 I have used a 245/70-16 without any problem. I usually get used truck tires.
   / Tubeless substituted for tubes tires. #5
most wheels will work either way
   / Tubeless substituted for tubes tires. #6
I have some older wagons with tube type wheels & the wheels don't have the dip for the bead to lock into. That is why the tubeless tires need to be wider.
Thanks to all. Stayed with the tube. Bought new tube and new tire.
2018 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A52576)
2018 KENWORTH T680...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2005 GMC Sierra Pickup Truck, VIN # 2GTEK13T851399344 (A51572)
2005 GMC Sierra...
2025 JOHN DEERE X350 LOT NUMBER 166 (A53084)
2025 JOHN DEERE...
JOHN DEERE LOT NUMBER 167 (A53084)
JOHN DEERE LOT...
2016 Kia Cadenza Sedan (A51694)
2016 Kia Cadenza...
