Tube Patches... What brands do you use or Do it yourself?
   / Tube Patches... What brands do you use or Do it yourself? #1
dlvonhelf
Northern, CA
"Nortrac" 25hp (Jinma with a YangDong Y385)
Anyone use old tire tubes as patches? I was wondering if this will work. I just replaced a couple tubes... Wondering if I should keep them for patches. Would that work with regular vulcanizing cement?
If you patch your own tubes, what brands seem to do good for you? I mostly see bicycle tube kits. No one seems to market for tractors. Thanks!
   / Tube Patches... What brands do you use or Do it yourself? #2
I personally have never had any luck using old tubes to patch with. I normally get my patches from the local tire shop I do business with for wholesale price. Often I wind up with an "assortment" of brands and types, but so far so good. I have found there patches to be much better than anything I could buy.
   / Tube Patches... What brands do you use or Do it yourself? #3
I've used old tubes as patches. You just need to cut it without any square corners and make the cuts so you have a tapered edge. I prefer commercially available patches, but making your own works.
Any reliable brands to recommend for patches and or glue? I'm not a fan of taking my tires off frequently to re-do patches...lol
   / Tube Patches... What brands do you use or Do it yourself? #5
I'm not sure of the brand but I order mine from All Tire Supply and the smallest tube of glue they have. Quality patches.
   / Tube Patches... What brands do you use or Do it yourself? #6
Rema is the brand that a lot of tire shops around here use.
   / Tube Patches... What brands do you use or Do it yourself? #7
When I can get them I use TECH brand. But that requires me to think ahead and order them. I find the glue dries out before I use it so I often get small tubes of it which is much easier done when you can just pop into a store vs buying on-line. I have used some patches/ cement from a company called BlackJack, they seam to work fine.
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
Sullair RD3800 Compressed Air Dryer (A47384)
Sullair RD3800...
PTO Powered Generator (A50515)
PTO Powered...
Case SV 340 Skid Steer Loader (A52349)
Case SV 340 Skid...
