TU1900F
/ TU1900F #1
jimstractors
Pearblossom CA
Iseki, John Deere
Just got in a TU1900F. Nice tractor. I have had a few TA series, but this is the first TU. Anyone have the WIX or NAPA filter numbers for this model?
Thanks,
/ TU1900F
Got the oil filter & fuel filter. Same as most Yanmars.
Still need air filter number if anyone has it.
/ TU1900F #3
A TL uses a Car Quest 88326, check the specs and see if it will work. Double check the oil filter. A TL uses a 1348. The 1334 will fit, but when I checked it against some other Iseki filters it was a loose fit and has been known to come off while in use.
/ TU1900F #4
kays supply is right on the oil filter. 3/4 and 20mm are very close, but the 20mm (0.787 inch) will blow off the 3/4 inch (0.750 inch) Iseki fitting.
1999 Dorsey 42' Aluminum Citrus Trailer (A64127)
1999 Dorsey 42'...
GATOR UTV (A63276)
GATOR UTV (A63276)
POULAN 44" VINTAGE 2 MAN CHAINSAW (A64276)
POULAN 44" VINTAGE...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2019 Toyota Mirai Sedan (A61574)
2019 Toyota Mirai...
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
