TU1900F
   / TU1900F #1
jimstractors
Pearblossom CA
Iseki, John Deere
Just got in a TU1900F. Nice tractor. I have had a few TA series, but this is the first TU. Anyone have the WIX or NAPA filter numbers for this model?
Thanks,
   / TU1900F
Got the oil filter & fuel filter. Same as most Yanmars.
Still need air filter number if anyone has it.
   / TU1900F #3
A TL uses a Car Quest 88326, check the specs and see if it will work. Double check the oil filter. A TL uses a 1348. The 1334 will fit, but when I checked it against some other Iseki filters it was a loose fit and has been known to come off while in use.
   / TU1900F #4
kays supply is right on the oil filter. 3/4 and 20mm are very close, but the 20mm (0.787 inch) will blow off the 3/4 inch (0.750 inch) Iseki fitting.
2011 KENWORTH T800 (A52472)
2011 KENWORTH T800...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
Crosley 10ft Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
20ft Bumper Pull Equipment Trailer (A51572)
20ft Bumper Pull...
