TU 180F Tranny/Rear end Lube?
   / TU 180F Tranny/Rear end Lube? #1
Bilko
Michigan
Mahindra Emax 25 / Allis Chalmers B
I need to change the tranny/rear end fluid in my TU 180F Landhope. I have tried to find a solid answer but have not been able to. Do I use hydraulic oil or gear oil?
Anyone have an Idea on what to use?
   / TU 180F Tranny/Rear end Lube? #3
Since no one is jumping in, I'll give it a stab.....I really can't give you a definitive answer but I find it hard to believe you could go wrong with universal trans/hydraulic fluid. Like you machine sounds to be set up, most tractors share the trans, hydraulic reservoir and rear end lubrication. A good quality UTF will satisfy most manufacturers standards and I feel comfortable in saying it is the correct choice.
   / TU 180F Tranny/Rear end Lube? #4
Ditto :thumbsup: . I,m not familiar with the 180F , but have had several other Iseki models & they all used the universal trans/hydraulic fluid .
FYI , When you get ready to drain it be prepared with lots of drain buckets, some models hold 15 gallons or so ;) . I dont know if you have an atwoods farm supply store in your area , but I beleive they have a sale on UTF in 5 gallon buckets for $22.50 this week ;) .
Thank you Kernopelli, and cowboy357 for your input. I believed that I needed to use universal hydraulic fluid myself. But at times I like to check with others to see what they have to say so I don't end up breaking something! I enjoy learning and with not many people owning Iseki's and not a whole lot of information on them I just wanted to make sure. Thanks again for your time.:thumbsup:
Mike
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
INSPECTION (A51573)
INSPECTION (A51573)
WORKSAVER RMB-325-PW LOT NUMBER 117 (A53084)
WORKSAVER...
2019 KOMATSU D51PX-24 CRAWLER DOZER (A51246)
2019 KOMATSU...
