TU 180F Tranny/Rear end Lube?
   / TU 180F Tranny/Rear end Lube? #1
Bilko
Michigan
Mahindra Emax 25 / Allis Chalmers B
I need to change the tranny/rear end fluid in my TU 180F Landhope. I have tried to find a solid answer but have not been able to. Do I use hydraulic oil or gear oil?
Anyone have an Idea on what to use?
   / TU 180F Tranny/Rear end Lube? #3
Since no one is jumping in, I'll give it a stab.....I really can't give you a definitive answer but I find it hard to believe you could go wrong with universal trans/hydraulic fluid. Like you machine sounds to be set up, most tractors share the trans, hydraulic reservoir and rear end lubrication. A good quality UTF will satisfy most manufacturers standards and I feel comfortable in saying it is the correct choice.
   / TU 180F Tranny/Rear end Lube? #4
Ditto :thumbsup: . I,m not familiar with the 180F , but have had several other Iseki models & they all used the universal trans/hydraulic fluid .
FYI , When you get ready to drain it be prepared with lots of drain buckets, some models hold 15 gallons or so ;) . I dont know if you have an atwoods farm supply store in your area , but I beleive they have a sale on UTF in 5 gallon buckets for $22.50 this week ;) .
Thank you Kernopelli, and cowboy357 for your input. I believed that I needed to use universal hydraulic fluid myself. But at times I like to check with others to see what they have to say so I don't end up breaking something! I enjoy learning and with not many people owning Iseki's and not a whole lot of information on them I just wanted to make sure. Thanks again for your time.:thumbsup:
Mike
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A52576)
2020 INTERNATIONAL...
McDon 75D Flex Draper Head (A52349)
McDon 75D Flex...
2014 Ford Escape (A50324)
2014 Ford Escape...
