TU 1700 - Transmission & Hydraulic fluid change
   / TU 1700 - Transmission & Hydraulic fluid change #1
wcpeabody
earth
JD 770
First I want to thank those that have helped me to this point.
Ok, now I am on to this weekends tractor project. So I started a new thread.
I need to change the transmission fluid, easy enough but I am a little confused and here are some questions:
  1. it looks like the Hydraulic pump is using the same reservoir, it that correct?
  2. Where is the screen - filter in the hydraulic system that should be cleaned out?
  3. What type of fluid should be used, TDH rated fluid ?
Attached are some photo's
Thanks in advance,
Bill
BTW - I am taking pictures of when I do this mainenance. I plan on making threads outlining what I did so when someone else has the same questions they can be directed to the thread
I got it figured out but there was more fluid then I expected. Some where around 4 liters. I only bought 3 quarts so I need to get to the store tomorrow and get some more before I know exactly how much.
Bill
   / TU 1700 - Transmission & Hydraulic fluid change #3
I like your idea to post pictures of your work.
I don't have a TU1700 but for those who do this will be helpful. I have learned a great deal about my TS1610 and tractors in general from posts on this site.
The first time I changed the engine oil in my TS1610. I found a quite a few extra pieces of gasket material in the pan. So it is worth the effort to change this on a tractor that is new to you.
   / TU 1700 - Transmission & Hydraulic fluid change #4
I had to refill after a PTO seal failure last year and to the best of my memory it took about 4.5 gals in my 2 wheel drive TU1700. Did not think I would every get it full. To NAPA 3 times to get enough.
Eddie
   / TU 1700 - Transmission & Hydraulic fluid change #5
You better recheck. It usually takes gallons not quarts.
Kay, thanks you are right. I mis "spoke" above.
   / TU 1700 - Transmission & Hydraulic fluid change #7
Do you know where the drain plug is for the hydraulic Reservoir? Or do you know how to drain the Hydraulic Reservoir on and Iseki TS1610, I know how to drain the Transmission Gear box!!! Just need help on how to drain the Hydraulic Reservoir?
Thanks
2004 Hydraulic Breaker Excavator Attachment (A52377)
2004 Hydraulic...
2023 John Deere HD40F Draper Head (A53342)
2023 John Deere...
LINK BELT LB-98 LOG LINE YARDER WITH MOTORIZED CARRIAGE (A52576)
LINK BELT LB-98...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
