Tu 150 ignition
/ Tu 150 ignition #1
xmariner
Bushnell, FL
LS XR4155HC
Here goes.
Problem: When rotating the ignition key forward to start the tractor, the entire ignition switch turns as well. It's getting to the point where I can't rotate my wrist far enough to reach the START position.
The switch and the hole through the steering column cover (which accommodates the switch) are both notched with a "key way".
It would appear that at one time there was a "keyed" washer that would have been placed over the ignition switch after the switch was positioned in the cover. Then the finish nut would be screwed on.
If anyone followed my lame description, do you have any ideas how I might solve this?
1999 Coachman Catalina RV/Camper VIN # 3FCMF53S2XJA29020 (A65563)
1999 Coachman...
Soil-Max Gold Digger (A64126)
Soil-Max Gold...
CATERPILLAR D8T CRAWLER DOZER (A64279)
CATERPILLAR D8T...
2016 Dodge Charger Sedan (A64557)
2016 Dodge Charger...
2015 Caterpillar 308E (A64126)
2015 Caterpillar...
2012 Ford F-150 Pickup Truck (A64194)
2012 Ford F-150...
