TU 1400 Iseki Fluid Checks
   / TU 1400 Iseki Fluid Checks #1
XXL
How do I check the Hydraulic fluid in this tractor? The lift works good, but would like to check out. Is DOT Type brake fluid OK?
How do I know if the rear gear lube is full? I see a red cap under the seat - What weight gear lube?
   / TU 1400 Iseki Fluid Checks #2
I can't speak directly to the TU1400, but I have a TU205 and the rear gear lube and hydraulic oil share the same sump. The TU205 has a dip stick in the fill cap located under the seat. We use a typical TDH rated fluid (Transmission, Differential, Hydraulics) available at any John Deere, Kubota, Cat dealer or everyones favorite, Wal-Mart.
TRASH TRAILER 16 T/A (A52472)
TRASH TRAILER 16...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2018 Club Car Carryall 500 Electric Utility Cart (A51691)
2018 Club Car...
2019 INTERNATIONAL LT625 (A52472)
2019 INTERNATIONAL...
