tsc subsoiler question
/ tsc subsoiler question #1
257NH
New Hampshire
New Holland TC40DA
Has anyone tried to bolt up a tsc middle buster blade to a tsc subsoiler?If so was it a direct fit?I ordered the middle buster part and I'm just curious what I'm in for.
/ tsc subsoiler question #2
I think that the bolt pattern is the same. I have the middlebuster so does RedBug but I have not unbolted the tooth and replaced it with the middlebuster.
/ tsc subsoiler question #3
I need to got the other way... bolt a sub-soiler blade in place of a middlebuster plow.
Any update from the OP?
/ tsc subsoiler question #4
I've got both - meaning not the one where you can bolt on either, but 2 separate. can go out and look if that would be helpful
/ tsc subsoiler question #5
I am interested in this also. The other day when I was at TSC, I looked at the subsoiler and if I remember right it appeared that the bolt pattern was different than the middlebuster they had setting ~15' away. Something was different but I didn't take measurements or anything.
/ tsc subsoiler question #7
rayh76 said:
Thanks for sharing. That is the KK brand subsoiler with the middlebuster right? Maybe the wife won't notice a small implement out with all the other junk. :)
hi ray,I'm pretty sure it says farm force on it,but it is from tsc.
/ tsc subsoiler question #9
You purchased the TSC subsoiler, wonder where you got the plow portion to bolt onto it. Also wonder if TSC sells just the replacement piece for the subsoiler.
I have purchased the plow from them, but did not see any subsoiler piece. I Was told they could order it, but I failed to do so when there. He compared the Farm Force unit with the KK unit and gave me the song and dance that they were absolutely the same.. Another salesmen is how I viewed that. KK will not take any ownership of Farm Force products.
Wayne
/ tsc subsoiler question #10
So, the bolt pattern is the same. Or at least close enough to work.
Are the vertical shafts the same length from the draft links down to the business end?
Charlesaf3, if you could go measure yours, that would be mighty appreciated.
Thanks,
Which friday charles.....lol
/ tsc subsoiler question #14
If you're talking about one of those yellow KK middle busters, I can't help you there. I own one of those red KK XB middle buster/subsoiler combos ($140 from TSC).
FWIW, the bolt holes in that XB unit mate with the holes on an arrowhead sweep that I got from Agri-Supply.
I prefer this sweep to the subsoiler to cut trenches for landscape irrigation PVC pipes.
/ tsc subsoiler question #15
yes, it is. I have bought several different sizes of sweeps from TSC and they have the same hole spacing. I eye balled a few others that did not seem to fit.
JC,
2021 JCB 3TS-8T TELESKID (A65056)
2021 JCB 3TS-8T...
KALMAR AC P50BX-PS WAREHOUSE FORKLIFT (A64276)
KALMAR AC P50BX-PS...
2017 CHEVROLET SILVERADO 2500HD (A65643)
2017 CHEVROLET...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
2026 323W Stand-On Mini Wheel Loader Skid Steer (A66734)
2026 323W Stand-On...
MAGNUM TRANSFER PUMP (A67714)
MAGNUM TRANSFER...
