tsc spring seat on 284
/ tsc spring seat on 284 #1
SPIKER
Elite Member
Ohio, Jeromesville, Ashland County
Jinma 284
hey all: I'm adding me a spring seat form TSC, they had them for 69.00 last month so I picked one up and am installign it on my jinma 284.. it won't work well with my backhoe but it is only on a few weeks a year usually or less. anyhow it is pretty straight forward seems to fit nice and all. It has 2 holes in the right front location for the 284 but they are about 3/8' and the bolts in the old mounts are 16 MM head (about 7/16" bolts and use a 5/8" socket as I don't have any 16mm wrenches.) the back bolts are where no holes were so I drilled 2 new holes in the plate for mounting. while drilling I reamed out the 2 front holes to 1/2" for added clearance. the seat can be installed after the mount plate is bolted down but it also slides to reach the bolts if you want to un-bolt the plate while it is still attached to the seat bracket.
the orriginal JINMA seat is still in great shape - one dent from a over raised top link /forums/images/graemlins/blush.gif I'll keep it hand when I have to re-install the backhoe that or make up a bracket for mounting theseat differently when the hoe is on /forums/images/graemlins/wink.gif anyhwo no pictures so far... maybe later.
MakrM
/ tsc spring seat on 284 #2
Mark,
I am getting ready to order one for my bare bones Farm Pro. I was going to order mine from Homier but it looks like they are out of stock.
http://www.homier.com/detail.asp?dpt=&cat=&sku=03084
I'm not going to put much more money into this tractor as I would like to move up in size in a few years. I do hear alot of great things about the spring seats though. Maybe I should check out TSC next weekend. Were they on sale?
/ tsc spring seat on 284 #3
Spiker,
Yep, the TSC spring seat is a big improvement over the original hard mount seat. Your kidneys thank-you! 3pt arm can still reach it though /forums/images/graemlins/wink.gif If you don't like swapping the seats, you could try my method: http://www.johnstractor.com/SwivelSpringSeat.html but, it is a bit more involved and more time consuming.
/ tsc spring seat on 284 #4
What prevents it from working with the backhoe. I've always been curious.
On the guilian /JINMA back hoe the tractor seat is set up with a piviot/swivel which is little more than a hunk of pipe inside a 2nd hunk of pipe and a pin runs through it. there is some sort of bearing in there as mine popped appart once when I left it set with out the PIN in which let the seat swing about a bit when I was setting on it and working the HOE.
anyhow for mine I modified my HOE main controls so I can opperate it standing up with out hunching over and this will/should give me a bit better control over the HOE anyway. (I did this a while back) JOHNS has excelent way of doing his seat conversion!
anyhow that HOMIER FARMPRO seat is exactly same thing. maybe TSC bought homier out? /forums/images/graemlins/blush.gif lol yes made in china no biggie to me so is the rest of the tractor.
MakrM
/ tsc spring seat on 284 #6
<font color="blue"> Yep, the TSC spring seat is a big improvement over the original hard mount seat </font>
Hey John,
I 2nd that Emotion. /forums/images/graemlins/smile.gif
Spring seats are definitely the way to go and in my humble opinion: "Don't Buy a Tractor Without One".
Get your tractors running &
Have a nice day,
Joe /forums/images/graemlins/cool.gif
2019 Dodge Charger Sedan (A64557)
2019 Dodge Charger...
2016 International WorkStar 7500 T/A Dump Truck (A64556)
2016 International...
Longhorn BBQ Bull Smoker (A65583)
Longhorn BBQ Bull...
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A65643)
2008 MOTIV...
New 2x27 Ratchet Strap (A65579)
New 2x27 Ratchet...
21ft Gooseneck Hay/Pine Straw Trailer (A65563)
21ft Gooseneck...
