TSC implements
   / TSC implements #11
TSC has started to carry Farm Force implements in some of the Northeastern stores. Farm Force is made by Tarter Gate and the design was based off of the King Kutter line with some changes (none good). They basically cut a few corners to save some cost; you can notice it mostly in the bracing and comparing the King Kutter rotary cutter and the Farm Force side by side. King Kutter uses an Omni Gear gearbox http://www.omnigear.com/ which is also the gearbox manufacturer for Bush Hog and Woods; Farm force uses a Cheetah brand which I have never heard of. Tarter just started making the Farm Force equipment within the past year and I would suspect they have some bugs to work out.
   / TSC implements #12
Since you, KK Fan, have no profile I'd say you work for KK or Taylorway/Pittsburg. Omni and ITG make many of the gearboxes for numerous cutter manufacturers, They both have priced Tarter on a KK style gearboxes. Likely Cosmo worked out a deal on a load Chinese gearboxes for Tarter since Tarter is going to sell Cosmo, Sicma, Euro-Cardan, Fort/Morra & Faza. Sounds a little like Buy Smart because the same Italians brokered the same deal. Tarter will be a combination of KK, Darrell Harp & Bob Taylor.
John Deere 270 Wheeled Skid Steer (A50322)
John Deere 270...
2018 John Deere 8370R MFWD Tractor (A50657)
2018 John Deere...
FRUITLAND VACUUM PUMP (A50854)
FRUITLAND VACUUM...
2006 IC PB30500 School Bus (A50323)
2006 IC PB30500...
2019 CATERPILLAR 326FL EXCAVATOR (A51242)
2019 CATERPILLAR...
2017 JOHN DEERE 624K-II WHEEL LOADER (A51242)
2017 JOHN DEERE...
