TSC 15 Gal fuel caddy
   / TSC 15 Gal fuel caddy #1
tomd999
Platinum Member
Viva Manchvegas!
'10 3320 cab
Hiya,
Not sure if this is where I should ask about fuel cans but here's my question:
Does anyone use the 15 Gallon caddy w/hose and fill handle from TSC? How are they for ease of use? Quality? Flow?
I was thinking of bolting 2 of them to a pallet, plumbing the outlets together into one hose/nozzle and when I needed to fuel up, lift it up on the forks and let gravity do it's work. When I needed to fill them, load it into the truck and visit the fuel oil guy down the road.
Tom
   / TSC 15 Gal fuel caddy #2
Might be cheaper to get a 35g steel drum ( grease keg ) and pop a pump in the bung hole..
soundguy
   / TSC 15 Gal fuel caddy #3
Hi tom,
I have one of those cans.If your going use it like you said it will do fine. When its full its a handfull to move around.Also the outlet and valve are on the bottom and not protected at all,but mounted to a skid as you say it will be that wont be a problem.I was going to try and do something like that but my fuel fill is all the way out back and I didnt want to screw around with a hose that long.So I registered my tractor instead lol.Now I just road it to the nearest station.
Brian
   / TSC 15 Gal fuel caddy #4
soundguy
and then fasten the drum to a pallet so that you can forkllift the whole thing into your truck.
I don't think that gravity will work for fuel running through a hand pump. But I may be wrong.
   / TSC 15 Gal fuel caddy #5
If you are going for gravity feed.. forget the pump.
soundguy
   / TSC 15 Gal fuel caddy #6
soundguy
I'd forget the Caddy and get Get a 100 dollar elect diesel pump a $30water Blocker filter and a $20 nozzle from Northern tool.
With this rig you can fill the tractor from amy container from a home heating oil tank 55 or 30 gallon drum 5 gallon cans even 1 or 2 gallon jugs.
   / TSC 15 Gal fuel caddy #7
tomd999 said:
Hiya,
1* I was thinking of bolting 2 of them to a pallet, plumbing the outlets together into one hose/nozzle and when I needed to fuel up, lift it up on the forks and let gravity do it's work.
*When I needed to fill them, load it into the truck and visit the fuel oil guy down the road.
Tom
1* Forget this.
Why not/Get a 100 dollar elect diesel pump a $30water Blocker filter and a $20 nozzle from Northern tool and let this do all the work?
*It will also unload the fuel off your truck when you get back fron visiting the fuel oil guy and totally eliminates having to dig out the tractor and forks.
2023 BOBCAT T770 SKID STEER (A52706)
2023 BOBCAT T770...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A54313)
2012 INTERNATIONAL...
2005 CATERPILLAR 730 OFF ROAD WATER TRUCK (A51406)
2005 CATERPILLAR...
HarbinGer V3 Plus S/A Towable Light Tower (A52377)
HarbinGer V3 Plus...
Kawasaki NR (A50324)
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
