TS354C question
/ TS354C question #1
DwayneB
Ky
JD 2240, NHTD80D
I noticed a plate on the side of the bell houseing, says lubricate or something like that. Does this model have a greasable throw-out bearing? Anyone know?
/ TS354C question
should last forever as long as it greased yes?
Thanks. i got a lot to learn.
/ TS354C question #4
</font><font color="blue" class="small">( should last forever as long as it greased yes?)</font>
Internally, perhaps. Externally, it depends on how well you keep the clutch adjusted. There's supposed to be a minimum 2mm gap between the fingers and the bearing face. If permitted to rub, they can damage the bearing housing.
//greg//
/ TS354C question
I got another question for you. The tach on my tractor reads around 600 at idle. sounds more to the ear to be about 800 or so, who knows. At full throtle a tad under 1600 is all I can get. Was yours like this from the factory? I wonder if i am 200 off or it needs adjusting.
/ TS354C question #6
Probably more than 200 Dwayne. If you've got the 485 engine, I'm thinkin' you should be able to rev to at least 2400. The tach sending unit is screwed into the side of the bellhousing so it can count flywheel teeth. With the tractor NOT running, loosen the locking nut and carefully screw the sending unit in till you feel it touch the flywheel. Back it out a quarter turn, and tighten the lock nut. See if that doesn't accurize your tach readings some. It may take some fine tuning, cuz closer is better. But finding the sweet spot can cost you a sending unit if it gets hit by moving flywheel teeth. Careful.
//greg//
/ TS354C question #7
I have the TS354C and it will peg the tach if I wanted to do it.
BIGDOGG
/ TS354C question
Thanks, I'll give that a try when I go to the farm saturday or sunday. I'll also be changing/cleaning spools on the LW-6 and I have a steering issue. Chip seems to think maybe the fluid is low or foaming or possibly a leak, but he's sending me a seal kit just in case. Darn thing wanders all over the road at speed and wheel spins freely sometimes before and after it hits the stops. Yes, its the 485 engine. Very smooth running engine. I think I was wearing poor Chip out with questions so I thought I would try getting a little info here.
/ TS354C question #9
I may be worn out by not by your doing! Gregs advice about hte tach sensor adjustment is right on, sometimes they get set just on the edge of working and get a weak signal that under counts the RPM. I know I'd hate to count those teeth at 2000 rpm or more. I don't even want to count them standing still!
/ TS354C question
hey Chip, good news. I drained the power steering and refilled with 30 wt hydraulic fluid. The steering is working great now. Fluid sure was dirty to. The tach adjustment worked to. I swapped backhoe spools, just the internal part and its a little better, but still not quite right. Its useable for sure and that's what i am going to do. When i set it off to mow later this summer. I'm going to disassemble the whole valve body and look for dirt/swap valve bodies. I'm thinking now perhaps that particular valve is just not machined exactly right.
2016 JLG 800AJ 4x4 80ft Articulating Boom Lift (A64553)
2016 JLG 800AJ 4x4...
2014 Kenworth T370 21ft. Flatbed Truck (A64194)
2014 Kenworth T370...
2022 EZ-GO ELITE...
2025 Electric Cart (A64557)
2025 Electric Cart...
JOHN DEERE QUICK HITCH (A64278)
JOHN DEERE QUICK...
2023 JCB 270T SKID STEER (A65053)
2023 JCB 270T SKID...
