TS1910 Replacement Battery
   / TS1910 Replacement Battery #1
chetorba
NE PA
Iseki TS1910, Kubota M5500
Does any one know the correct size battery for a TS1910. The specifications state the the battery is a 12 volt 65 amp. How does that relate to CCA (cold cranking amps)?
   / TS1910 Replacement Battery #2
I think it depends on the particular battery how it tests for CCA, which is amps available at 0-deg.F. for a certain short period of time. A MF-1020 which has a 3-cyl. diesel of about the same HP rating as the TS1910 (21HP) uses a recommended battery with 475 CCA. That should get you in the right ballpark. Apparently the old amp-hours rating of 65 to 70 is not used by the industry much anymore.
Bill
   / TS1910 Replacement Battery #3
Any battery about the same length width hight with the post in the same position that will fit in the battery box will work.
Thanks to both of you for the info
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A52748)
2016 KBH...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2012 FORD F-650 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2012 FORD F-650...
