Tires TS1910 Rear Tire Tube
   / TS1910 Rear Tire Tube #1
chetorba
NE PA
Iseki TS1910, Kubota M5500
My rear tire went flat. Does the rear tire of the TS1910 have a tube? If so, does anyone know the size and where to get one?
   / TS1910 Rear Tire Tube #2
Don't know the size of the tube on this model but there are sources for service manuals and parts lists available. I have had good luck using the following parts suppliers that can probably get you a new tube if necessary.
Your tractor is also known as a Bolens G192 for two wheel drive and a G194 for the four wheel drive model.
Bolens - Iseki Diesel Tractor Models
Tractor Manuals - Iseki Tractor Manuals - Bolens Tractor Manuals
Homestead also carries parts manuals and service manuals for the TS1910.
   / TS1910 Rear Tire Tube #3
pm lens12 he will have the info and probably the tube
   / TS1910 Rear Tire Tube #4
Most tractors use tube type tires.
   / TS1910 Rear Tire Tube #5
Go to any tractor supply. There's nothing special about the tires and tubes.
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2012 VOLVO VNL TANDEM AXLE SLEEPER (A52576)
2012 VOLVO VNL...
2007 Eager Beaver 35 GLB Lowboy, Tandem Axel (A52384)
2007 Eager Beaver...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2024 KMC 7406 (A53084)
