ts1910 plugs
/ ts1910 plugs #1
abee6743
bobcat ct230
what are the small hex bolt plugs under the brakes, trans and under the clutch housing i think they are 10 mm bolt heads.
Thanks
Andy
/ ts1910 plugs
I have taken out all the plugs. nothing came out. the trans plug is square.
/ ts1910 plugs #4
I might be confused over the plugs you are asking about. A picture would help. One plug on the side of the trans is the fill plug and you would not expect anything to come out. My tractor has three drain plugs on the underside that are for draining the gear box oil. The motor oil pan has two more plugs.
/ ts1910 plugs
the plugs I am talking about are the two under the brake housing, one under the clutch housing and one under the trans they are smaller than the trans drain plug.
thanks
/ ts1910 plugs #6
Not sure what those smaller (12mm) plugs are either. Can someone tell me where the transmission drain plug is on the ts1910?
/ ts1910 plugs #7
I found the answer on a different thread, it is the square plug under the rear differential.
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
New/Unused Landhonor 12V Diesel Pump (A65583)
New/Unused...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
Unverferth 275 (A64126)
Unverferth 275...
Speed Trailer (A64194)
