ts1910 plugs
   / ts1910 plugs #1
abee6743
bobcat ct230
what are the small hex bolt plugs under the brakes, trans and under the clutch housing i think they are 10 mm bolt heads.
Andy
   / ts1910 plugs
I have taken out all the plugs. nothing came out. the trans plug is square.
   / ts1910 plugs #4
I might be confused over the plugs you are asking about. A picture would help. One plug on the side of the trans is the fill plug and you would not expect anything to come out. My tractor has three drain plugs on the underside that are for draining the gear box oil. The motor oil pan has two more plugs.
   / ts1910 plugs
the plugs I am talking about are the two under the brake housing, one under the clutch housing and one under the trans they are smaller than the trans drain plug.
thanks
   / ts1910 plugs #6
Not sure what those smaller (12mm) plugs are either. Can someone tell me where the transmission drain plug is on the ts1910?
   / ts1910 plugs #7
I found the answer on a different thread, it is the square plug under the rear differential.
2025 Man Basket Forklift Attachment (A49346)
2025 Man Basket...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A50397)
Mitsubishi FG35...
2017 Ford F550 4x4 Bucket Truck - 45FT Terex TL40 Boom, Powerstroke Diesel, Utility Bed, 54K Miles (A50397)
2017 Ford F550 4x4...
2021 CATERPILLAR 299D3 SKID STEER (A50458)
2021 CATERPILLAR...
2025 Kivel 42in. Forks and Frame Mini Skid Steer Attachment (A49346)
2025 Kivel 42in...
2013 Dodge Charger Sedan (A48082)
2013 Dodge Charger...
