TS1610 new owner hydraulic oil and gear oil question
   / TS1610 new owner hydraulic oil and gear oil question #1
lama
Does the tranny and hydraulics share the same oil?
Does the tranny and rear-end share the same oil?
There is a small hose coming from behind the shifter to under the seat, is it suppose to connect under the seat or are the two holes vents that should both have seperate open hose? Any help,,, Thanks
   / TS1610 new owner hydraulic oil and gear oil question #2
The transmission and rear end share the same oil. Owners manual says use 90wt.
Hydraulics uses hydraulic oil. The hose on mine is connected from the shifter to a tube in the "Tool Box". Owners manual confirms they connect together.
So it is not a vent and should be connected together?
Do you know where the filter screen for the hydraulics is located, or if it even has one? Thanks for the info on the fluids
   / TS1610 new owner hydraulic oil and gear oil question #5
Yes, they should be connected together. There is a filter screen in the flange where the hydraulic suction line bolts to the case of the hydraulic unit. Suction is the big line.
Thanks for all the help! This is a great forum.
   / TS1610 new owner hydraulic oil and gear oil question #7
I have a TU240f, does the same hold true for weight, locations, etc.?
(1) 300 Gallon of Double Concentrated Car Wash Soap (A51573)
(1) 300 Gallon of...
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
2017 Club Car Carryall 1700 (A51573)
2017 Club Car...
2025 New/Unused Wolverine 72'' Skid Steer Ripper (A51573)
2025 New/Unused...
2007 INTERNATIONAL MA025 (INOPERABLE) (A52472)
2007 INTERNATIONAL...
