ts110 New Holland remote valve question
   / ts110 New Holland remote valve question #1
ChuckFinch
Arkansas
TS110
I have a ts110 and my loader works off of the rear remote behind the cab. What I don't like is that the valve has detents in every direction. Plus it doesn't take much travel of the joy stick in the cab to place it in detent position. I find myself with the loader still moving up or down when I let go from the stick to shuttle directions on the tranny.
Can anyone tell me how to disable the detents? I think it may be a 408 but not certain of the type of valve it is. Messicks give a part number of 81864. It is the same as my Ford 4630. It stands upright and is the only valve I have seen on these tractors.
Just in case anyone wants to know, it is not a mid mount valve. I have to run the loader hoses over the batt box and rear end to the rear of the cab to hook up the 4 loader hoses.
   / ts110 New Holland remote valve question #2
On the valve body above the couplers there is an Allen Head screw with a 17MM jam nut. This adjusts the pressure for the detent kickout. You could back the screw out as far as possible to lower the kickout pressure. Might not fully disable the detents, but could lower the pressure threshold enough to be liveable. Second alternative is to remove the detent cap and take some parts out so it is impossible for the detent to function at all.
Thank you Rick. I will give it a try.
2015 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A58214)
2015 INTERNATIONAL...
kids dirt bike (A56859)
kids dirt bike...
Truck Metal Cargo Storage Box (A55787)
Truck Metal Cargo...
New/Unused Pallet of Ground Protection Mats (A57454)
New/Unused Pallet...
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
Hypertherm Powermax65 Plasma Cutter w/Cart, PIN 083266, S/N 65-067003 (A59076)
Hypertherm...
