3-Point Hitch TS100A 3-Pt. Flow Rate
   / TS100A 3-Pt. Flow Rate #1
sprint27c
We recently picked up a real nice 2004 TS100A and have done quite a bit of mowing and moldboard-plowing with it....its been a real nice and capable tractor so far.
One thing that really bothers us is the flow rate of the 3 point hitch. Its rather slow and for plowing that is a problem as the plow will drag several feet before digging in - forcing us to slow down at every turn. The obvious solution is to increase the rate that the hitch drops. The non-obvious thing is how to do that. All of the JD units we have - have a simple adjustable knob in the cockpit. The TS100A has no such knob and no mention of any adjustment in the manual.
I've talked to 3 different NH dealers and amazingly...none of them could come up with a how-to answer on where this adjustment is and how to change it.
So how about the experts on this board???
   / TS100A 3-Pt. Flow Rate #2
If it has electronic draft control, the second knob from the left on the EDC panel controls rate of drop. If it has manual draft control and Lift-O-Matic, tighten the L-O-M cable at the hitch valve end. About 1 full turn should help.
Have you ordered an operator's manual yet?
It has the manual w/ LOM. I'll get a look at the cable and see what I can find.
I have an operator's manual which mentions the rate control but never actually outlines how to make the adjustment or where it is.
I do have a maintenance manual on order...cut a deal w/ my dealer for $200 for the whole book.
   / TS100A 3-Pt. Flow Rate #4
The L-O-M cable adjustment is separate and distinct from the hitch drop rate adjustment. But a cable a little too long will slow the hitch drop rate, and about 15% of LOM equipped tractors need this adjustment. The factory drop rate setting is usually adequate if the cable is in adjustment.
(3) Telephone Poles (A50515)
(3) Telephone...
1999 UTILITY 102" X 53' REFER TRAILER (A51243)
1999 UTILITY 102"...
2014 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2014 GENIE...
2000 INTERNATIONAL 4700 - 4X2 GARBAGE HAULER TRUCK (A51243)
2000 INTERNATIONAL...
2015 FREIGHTLINER (A50323)
2015 FREIGHTLINER...
HEAVY DUTY QUICK ATTACH PALLET FORKS W/ 48" FORKS (A51244)
HEAVY DUTY QUICK...
