TS 1610 Hyd. Problem. I think!
   / TS 1610 Hyd. Problem. I think! #1
jheat5
Actually had a TS 1610 Iseki gave to me. Only 125 hrs. I know its hard to believe. Here is the catch. rear hyds. with only lift a 4ft box about 2-3 inches. My bet is a blown seal? Anyone have any input on problem/cost to repair? SHe lifts up without anything on and does not make any noices. It just won't hold anything up. Thank, Jeff.
   / TS 1610 Hyd. Problem. I think! #2
Have you checked the fluid level?
Eugene
   / TS 1610 Hyd. Problem. I think! #3
I had a Hinomoto that sheared the key in the pump shaft. It was a simple fix.
I've shecked the fluids and all are fine. It will lift fine with "no" weight on the arms. Then after you mount an implement, it will lift to some degree, contingent on the weight of the implement. It will not however, hold the tool up. It "leaks" by and lowers it to the ground.
2018 Nissan Titan Pickup Truck, VIN # 1N6AA1E57JN515039 (A51572)
2018 Nissan Titan...
2023 Yamaha YXZ 100R SS (A51573)
2023 Yamaha YXZ...
19200 (A50324)
19200 (A50324)
2014 International WorkStar 7400 Truck, VIN # 1HTWGAAR9EH765325 (A51572)
2014 International...
New Long Forks (A53002)
New Long Forks...
TRUCK FLATBED (A52472)
