trying to trade tractor
   / trying to trade tractor
central wisconsin and this will be the third time the dealer has had to come haul it away. the other times i brought it in.
im not sure where it is leaking from, and the dealer has been great so far. but we are waiting on mahindra. and mahindra is located in tomball texas which is about 25 miles from houston. and rita could delay my answer for days. do you have any direct numbers i could try. thanks in advance
   / trying to trade tractor #13
I have had the same problems with the 2810 model also.
We found the seat switch was out of adjustment.
There are 3 safty switches that it has to go thru befor it will start.
I know that mahindra has had a bad batch of the computer for the 2310-2810-3510. After replacing 2 on a machine we got a good one.
If you tip your seat up and let it bounce when you put it back down it bends the strap metal that the safty switch is mounted to resulting in the switch going out of adjustment.
Just trying to help
   / trying to trade tractor #14
justin
please call me and I will give you good news
(570) 689-7494
its not that its always broken. its just always broken when i need it.
i wanted to plow the driveway when i brought it home, but the lights didnt work had to wait till morning - no big deal. dealer fixed the problem right away.
started cutting firewood a few weeks later, i was pulling the logs back to the house, however something came loose and the tractor was stuck in the woods, it wouldnt move. my dealer came picked it up fixed that in a few days.
i mowed a large area for my deer food plot, had it sprayed. then came time to plant, the tractor was leaking fluid and it was in the shop for two to three weeks again.
a month ago i was doing the rough grading on my yard i turned the tractor off and it would not turn back on. dealer picked it up in a week fixed it and brought it back a couple of weeks later. however i had to turn it off with the manual lever. there were still waiting for some module to come in. but they came out to replace that so i wasnt out.
now here i am again yard unfinished, piles of gravel in the driveway which were delivered and not spread out, retaining blocks for my landscaping siting there next to the black dirt to be spread. but nothing to do the work with. because it wont start again. dealer was supposed to pick it up on monday but got busy so its still in my garage.
   / trying to trade tractor #16
I talked to my Mahindra rep yesterday and he thought they would close down the Tomball facility today and tomorrow out of caution regarding Rita.
i checked under the seat and its not bent
   / trying to trade tractor #18
Justin you will be receiving you new parts
You will be getting the module and the wiring harness.
Just inform your dealer.
   / trying to trade tractor #19
i drove 70 miles to buy from a dealer i felt good about. da*n you make me want to drive 1845.52 miles (mapquest) to buy another. GOOD JOB.....
you are right anybody reading this should know that wallace is not my dealer, nor have i ever met him before. but he is trying to fix my problem. if you are in the market for a new tractor give this man a call. unbelievable
Rubbermaid 100 gal Poly Tank (A50515)
Rubbermaid 100 gal...
2012 JOHN DEERE 333D SKID STEER (A51242)
2012 JOHN DEERE...
Heritage / Woods RD 72 3 pt Finish Mower (A50515)
Heritage / Woods...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2012 MACK PINNACLE CH613 FLAT TOP DAY CAB ROAD TRA (A51243)
2012 MACK PINNACLE...
2025 Future Stump Grinder Mini Skid Steer Attachment (A50322)
2025 Future Stump...
