Trying to locate a water tank
   / Trying to locate a water tank #1
RHughes
Autauga County, AL
New Holland TN65
I'm trying to find one of those large, square, metal caged water tanks. I believe they come in 250 and 330 gal sizes; either size would be fine. Last year someone had an ad in the local classifieds with a couple of those to sell. They weren't expensive, only $40 or $50 but I passed on it and I've regretted it ever since.
I've found some on the internet, but the shipping is just too too expensive for the oversized item. I'm trying to find one relatively close so I can just go pick it up.
Do any of the other TBNers here in Alabama know of a source?
Thanks !
   / Trying to locate a water tank #4
If you're talking about the plastic tanks enclosed in an aluminum grid-type housing...... around here the local municipal water treatment plant gets chemicals in them and they find their way out in the public. If you are near a large city you might check at the water treatment plant.
Thanks for the help! I've got a few contacts in the local county seat so I try their water treatment facility first. If that falls through, I'll put an add in the Alabama Farmer's Bulletin.
   / Trying to locate a water tank #6
Outfits that sell new/used/refurbished barrels and drums will handle these IBC tanks. While you really want to know what they contained originally if buying "as is" used, refurbished should be safe enough for most purposes. They are very nice tanks.
   / Trying to locate a water tank #7
if you do find and purchase a used tank, Be very careful on what was in it.
   / Trying to locate a water tank #8
Check in any manufacturing site. Furniture makers use water base glue? Binders for concrete sometimes are water based acrylic material. Drive through an industrial park and look around. Check with large trucking companies with terminals.
   / Trying to locate a water tank #9
I had those tanks here for sale. Out right now but yeh they had fruit flovors for food in them and tea concentrate in them.
Where on a palet with metal conduit type cage around the poly tank.
$40 to $50
I probably sold 50 in several months now I see them tanks all over town.
   / Trying to locate a water tank #10
Hey Glenn, I can't get the LA mkt bulletin to ever load. MS bulletin loads no problem. Both are PDF. You got any ideas? Sure would be nice to shop from overseas.
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
2015 Chevrolet Silverado 2500 HD Crew Cab Pickup Truck (A50323)
2015 Chevrolet...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
2023 FORD F-250 SUPER DUTY (A52472)
2023 FORD F-250...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
