Trying to go smaller - what are my options?
   / Trying to go smaller - what are my options? #1
Adam23
Upstate, South Carolina
Kubota B7500
Hey all,
I could really use your guy's help. I have very litttle tractor knowledge/experience so I am relying on you all knowledgable folks for advice! :) I just sold my Yanmar becuse it is just a little to big and cumbersome for what I need. After playing with the Yanmar I now have a much better idea of what I need in a tractor. My problem is I am not sure what make/model I should persue. I am open to John Deere or Kubota or anything else really. This is what I would like:
Diesel Power around 17-19 horse
Hydrostat trans
4 wheel drive
front loader
around 60 inch belly mower
3 pt hitch 540 PTO capable of a small bush hog
Is there anything out there with these specs that is a good reliable tractor with good parts availablility? What make/model, year range? What price range should I expect to pay. I REALLY appreciate any imput on this as I am not sure what direction to go, but with the grass growing, I need to make a decision fast! Thanks again!
   / Trying to go smaller - what are my options? #2
Sounds like a sub-compact might suite you needs just fine. They are very nimble in tight spots, good at mowing, and are available with loaders. Check tractorhouse.com. Look at Kubota BX..., NH TZ..., Deere 2210 and 2305, Massey 2200, etc. Agco and Mahindra also have subcuts, but I am not sure what the model numbers are.
   / Trying to go smaller - what are my options? #3
If you have a Kioti dealer around, take a look at a CK20 HST. I love mine and bet it can outperform anything else near or in it's price/size range and will have more standard features like a suspension seat, fender mounted FEL controls, rear and mid PTO, cupholder, etc... Depending on your area, it should be cheaper too!
It will be a little heavier if you are looking for a primary mowing machine but there are plenty of users that mow with the 5' belly mower with no problems, you might just want turfs instead of industrials or ag's.
Good luck shopping.
   / Trying to go smaller - what are my options? #4
+1
Kubota BX and Deere 2305 would be my top picks on that list. Kubota had an issue with the BX fenders cracking but I think it's fixed; read the Kubota forums to make sure.
   / Trying to go smaller - what are my options? #5
As others have stated sub or small compact.
subs have been covered
Small would be
Deere 2320 / 2520
Kubota B7510 B7610
NH TC18 thru TC26DA
Check the classifieds on tbn - hint hint.
   / Trying to go smaller - what are my options? #6
You can't really go wrong with any of them reliability wise. The biggest difference is in ergonomics and dealer availability in your area. Decide how far you are willing to drive for good service, and look at all dealers inside that circle. Once you have the dealers worked out, you can decide on the specific machine.
Kubota has the most options in the 15-20HP range. But maybe try picking a price range you're comfortable with and go from there - you may be able to afford a 20-25HP model. Go bigger if you can. When getting price quotes, make sure the unit has a FEL and similarly sized mowing deck. From there, machine ergonomics will decide for you.
In my case, the JD 2305 and Kubota BX2450 were the same price. The JD ergonomics were a more comfy fit, but the real seller was the wife complaining about the orange paint color (our house is olive green). You'll find a reason to choose one over the other after playing with each a couple of times.
   / Trying to go smaller - what are my options? #7
   / Trying to go smaller - what are my options? #8
Adam23 said:
Hey all,
Hydrostat trans
4 wheel drive
front loader
What Yanmar did you have? You stated it was a bit too big... so that could help everyone point you in the right direction.
Thanks everybody for the responces so far. This gives me a little better direction. I had a YM2310 with AG tires 26HP FEL. It ws just to combersome. I think I need something between that and a lawn tractor. What should I expect to spend on a good used unit in the above recomemded models? What size bush hog would something that small run? 4 foot? Thanks again for everybodys response - what a huge help this board is!!
   / Trying to go smaller - what are my options? #10
The YM1610D would be an identical unit to what you had except smaller. Right in between a sub and compact. Still a shuttle shift and still a 3 cylinder but with 4wd. Perfect size for the 4 foot mower. Not a hydrostatic, but you wont drop 20% to 30% of your horsepower like a hydro. Price should be around 6k+ with new loader depending on what part of the country you buy it from.
If your dead set on a hydro I agree with Jonbrovado, I like that little Mahindra 1815HST. Or the Iseki built Massey’s
Buck
2005-  3412 ENGINE (A50854)
2005- 3412 ENGINE...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A50046)
2018 FREIGHTLINER...
2022 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2007 Ford E-350 Cargo Van (A48081)
2007 Ford E-350...
2014 VOLVO VN SERIES DAY CAB (A50854)
2014 VOLVO VN...
2023 Komatsu WA320-8 Articulated Wheel Loader (A49461)
2023 Komatsu...
