trying to find part
/ trying to find part #1
boggen
Elite Member
Trivoli, IL
SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
allis chalmers CA 1954
generator = 26 (stamped on it) no other numbers beyond F and A and those are for wire connections.
6v volt system
distributor / coil on it
i am looking for the posts more specifically the plastic washer were F and A screws go through the casing.
1 cracked to point it look like it was allowing electricity to go from screw to casing...due to missing large portion of it. (i think causing parasitic leakage i was seeing on meter with tractor off)
and the other use-able (pictured) is cracked as well.
i been tempted to use a rubber washer like a garden hose washer, but i am a tad iffy on sparks between were it protrudes inside and the coil right there, (am wanting the lip were the screw head fits down inside)
i have also thought about the paint on rubber for electrical connections and like. but. doubt it would last.
/ trying to find part #2
6v volt system
View attachment 509377 View attachment 509376 View attachment 509375 View attachment 509374
This looks like a job for a 3-D printer...
/ trying to find part #3
That's probably a standard part in the alternator industry; if you have a shop that rebuilds alternators and starters nearby they'd likely have one on hand.
/ trying to find part #4
The generators are a cheap and easy to find. I have several out back, but shipping would be an issue, considering you live right in the middle of where those tractors are abundant. They are few and far between down here.
David from jax
2020 GMC AT4 CREW CAB TRUCK (A60430)
2020 GMC AT4 CREW...
(2) BUNDLE OF MISC SIZE USED TIN UP TO 31' LONG (A62131)
(2) BUNDLE OF MISC...
2015 Bobcat T770 Compact Track Loader (A64047)
2015 Bobcat T770...
2021 Soil Warrior 4500 (A63116)
2021 Soil Warrior...
Harlo HP6500 (A60462)
2007 TEREX ADVANCE MIXER FD3000 AWD 6X6 FRONT DISCHARGE MIXER (A59910)
2007 TEREX ADVANCE...
