dusty3030
- Joined
- Jun 4, 2008
- Messages
- 2,263
- Location
- West TN
- Tractor
- Kubota MX5400 Cab, Kioti NX6010 Cab, Kioti RX7320 PS/ Cab, Kubota M7040 HDC, John Deere 2355, Kubota U35-4, John Deere 317G
I've got a 2355 Industrial / 2wd / JD 110 Loader and a JD 709 cutter trying to decide on fixing or replacing.
The 2355 has 3,270 hours. Blows a puff of white smoke if you let it idle for awhile and give it throttle. I think the clutch is on it's last leg.
The 709 cutter is heavily worn. I have it welded up everywhere it has cracked on the deck, but I need to replace the seals on the gearbox too, leaks out and has to be filled everytime I use it.
Good points is it has a 4 post ROPS, heavy duty skid plate and front bumper / grill guard. I replaced the batteries, alternator and muffler within the last couple of years. I put new tires on it about 4 years ago and they are still good. Rebuilt steering cylinders and replaced rockshaft seals in the last couple of seasons so no more putting in hyd fluid everytime I needed the tractor.
My gut says that the clutch is on borrowed time and I'm leary on the blowing a little smoke. It doesn't use oil enough to notice or add between changes, but It's got me concerned.
I've gotten a good quote on a Mahindra 5035 shuttle w/ loader and got them to come up with a good price on throwing in a 7' HD cutter in the package. I am considering this model because it can do what I am used to doing with the larger JD, but is smaller in height so I can clean stalls with it as well that I can't fit the JD into because of height. I can't pay cash for a new right now and that bothers me, but with 0% financing available borrowing to buy it doesn't sting so bad.
So after a long winded intro, here's my question. I put my 2355 and cutter on craigslist for $9,000. I got one lowball offer of $6,000 right off the bat (sounded like a dealer / used tractor trader) I passed on immediately. I also have had a local fellow come out and look at it and he is interested. I've been fully open on tractor, history, and problems, not trying to swindle anyone. I think he is going to counter at 6,000 or 7,000. Should I take the 6 or 7 thousand and run down to the Mahindra (or other) dealer or drop a couple of thousand in the old JD and keep on trucking without payments. I need a tractor to maintain our homestead (10 acres) 1/2 mile gravel driveway and move round bales to feed our horses in winter.
