Trying to adapt 7 spine brush hog to 15 spine PTO
   / Trying to adapt 7 spine brush hog to 15 spine PTO #1
chirodoc
Powerking tractor 15 spine rear PTO / 3 pt hitch. Need adaptor/coupler to attach to 7 spine brush hog shaft. Any advice where to go or what to do?
chirodoc
   / Trying to adapt 7 spine brush hog to 15 spine PTO #2
The JPG that you posted is not showing up...
I think that the 15 spline pto spins at 1000 rpm. Your mower is probably meant for 540 rpm. You need to confirm this because it would be _very_ dangerous to overspeed your mower. Any way to find out for sure what speed your PTO is on your tractor?
   / Trying to adapt 7 spine brush hog to 15 spine PTO #3
Surplus center is probably your best bet but if you tractor is a 1000rpm than you will need a speed reducer. Surplus center has one. I have seen them on ebay too.
   / Trying to adapt 7 spine brush hog to 15 spine PTO #4
Most 540 equipment is on a 6 spline 1 3/8 shaft.. If you have 15 or 21 splines.. I'd check rotation and speed before i just bought an adapter.
Who makes powerking? And waht hp is it / category? Lots of class 2 tractors that are 80hp and up are either 1000rpm pto, or selectable for either.. etc.
I had a valmet once that had a 540 pto.. but was multi-splined. Was like finding hens teeth to get the correct adapter.. course this was 16 years ago..e tc.
Soundguy
Husqvarna 120 Chainsaw (A51573)
Husqvarna 120...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
MASSEY FERGUSON 492 TRACTOR (A51406)
MASSEY FERGUSON...
Yale MPB040-EN24T2748 4,000lbs Electric Walk-Behind Pallet Jack (A51691)
Yale...
2017 KOMATSU PC228USLC-10 EXCAVATOR (A51246)
2017 KOMATSU...
2008 UTILITY DRY VAN TRAILER (A52576)
2008 UTILITY DRY...
