Try extending your 3pt hitch lever
   / Try extending your 3pt hitch lever #1
farmacist
Saranac, New York
TC35D
I use my 3 pt hitch a great deal and I found I always had trouble "finding it" without looking because it was a little low for me. I extended it up 6 inches and now it is easy to find and sits just below my joystick head. To try out this idea you can take a 9 inch long piece of 1 1/4" plastic pipe and just slip it over the head of the 3 pt lever. If you like it you can later make a permanent extension or just slip the pipe on when you are going to use it a lot.
Try it, you will like it. Frank
   / Try extending your 3pt hitch lever #2
</font><font color="blue" class="small">( I extended it up 6 inches and now it is easy to find and sits just below my joystick head. )</font>
Frank, that sounds like a really clever solution to your problem. Did you make a permanent extension? Does the extra leverage also give you finer control of the lever? /forums/images/graemlins/cool.gif
Yes- after trying it I made a permanent lever out of 2 pieces of plywood which bolt together over the lever. I did not want to weld on an extension but this wood lever extension works and yet the next owner can put it back to orriginal. The longer lever also makes it much eisier to feather the adjustment to the right height and my hand does not have to travel far from the joystick to the 3pt lever. Frank
2007 KENWORTH W900B (A58214)
2007 KENWORTH...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A56859)
2004 Fleetwood...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
PALLET OF MISC (A58374)
PALLET OF MISC...
MINI KID DIRT BIKE (A56859)
MINI KID DIRT BIKE...
