Try extending your 3pt hitch lever
   / Try extending your 3pt hitch lever #1
farmacist
Bronze Member
Saranac, New York
TC35D
I use my 3 pt hitch a great deal and I found I always had trouble "finding it" without looking because it was a little low for me. I extended it up 6 inches and now it is easy to find and sits just below my joystick head. To try out this idea you can take a 9 inch long piece of 1 1/4" plastic pipe and just slip it over the head of the 3 pt lever. If you like it you can later make a permanent extension or just slip the pipe on when you are going to use it a lot.
Try it, you will like it. Frank
   / Try extending your 3pt hitch lever #2
</font><font color="blue" class="small">( I extended it up 6 inches and now it is easy to find and sits just below my joystick head. )</font>
Frank, that sounds like a really clever solution to your problem. Did you make a permanent extension? Does the extra leverage also give you finer control of the lever? /forums/images/graemlins/cool.gif
Yes- after trying it I made a permanent lever out of 2 pieces of plywood which bolt together over the lever. I did not want to weld on an extension but this wood lever extension works and yet the next owner can put it back to orriginal. The longer lever also makes it much eisier to feather the adjustment to the right height and my hand does not have to travel far from the joystick to the 3pt lever. Frank
2025 JMR 40in Single Cylinder Hydraulic Grapple Rake Mini Skid Steer Attachment (A50322)
2025 JMR 40in...
2012 Cat 272C Skidloader (RIDE AND DRIVE) (A50774)
2012 Cat 272C...
2019 HINO 195 16 FT BOX TRUCK WITH LIFT GATE (A52576)
2019 HINO 195 16...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
Chevrolet C8500 Flat Bed with a Moffet Kit (A52748)
Chevrolet C8500...
