Trunion shaft seal replacement
   / Trunion shaft seal replacement #1
MFP8055
I've got a 1210 with a nasty fluid leak from the trunion shaft seal. I see that there's a snap ring and washer outside the seal. The big question is whether the seal can be replaced without tearing the unit apart. Any thoughts on ways to pull this off? The seal in question is the right side seal, not the one on the lever side.
   / Trunion shaft seal replacement #2
As long as you can get to the seal all you need to do is remove the snap ring and washer then punch a hole in the seal and use a slide hammer to pull it out. Drain the oil to below the level of the seal first.
Has anybody tried this method yet? Sounds like what i had planned to do, but I didn't want to get started and then find a problem that put the tractor on a shelf for a week.
   / Trunion shaft seal replacement #4
Never done this on this particular machine, but have done a pinion seal on a F150 this way before and it works great.:thumbsup:
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
S/N: 5D121002416 (A55787)
S/N: 5D121002416...
Miller Big 40 Portable DC Arc Welder Generator (A55973)
Miller Big 40...
2018 FREIGHTLINER CASCADIA 126 SLEEPER (A57880)
2018 FREIGHTLINER...
2006 Grove TMX25 (A55973)
2006 Grove TMX25...
Enmark Z Spray (A53316)
Enmark Z Spray...
